Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-04-2011, 10:19 AM
MeŠiCX MeŠiCX is offline
2013 Ford Explorer Sport
MeŠiCX is starting off with a positive reputation.
Unhappy 2008 Expedition Ltd Rear Brakes??
I bought my Expedition last November with 35K on it. At the time, dealer said front brakes were 75% and rear 100%. Didn't think anything of it. At about 50K, I had front rotors turned. Pads were at 50% so they were sanded and reinstalled. Rear brakes again were "like new". I had shop verify the were working and afterwards braking was smoother than before. No more "Chevy nose dive breaking" after that.
Yesterday, I had both my normal shop AND local dealer check the brakes. Both said I have 10K miles before front needs rotors and pads. Rear brakes were still "like new". At 73,000 miles, how can these rear pads and rotors be like new?? I read awhile back there was an issue with the hydraulic valves sticking and not opening for the rear brakes.
  #2 (permalink)
Old 10-04-2011, 11:04 AM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
Not sure, if they were not working properly you would have a hard time stopping and the fronts would be gone in about 20K miles.
My dads Nissan Titan truck went 103K miles before ever needing brake pads, I know, I didn't believe it either.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 10-04-2011, 01:09 PM
pgonza2723 pgonza2723 is offline
2008 Lincoln Navigator
pgonza2723 is starting off with a positive reputation.
That is strange cause with the Navigator the opposite seems to be true. The rear brakes were shot around 45k... then again at 78k. Replaced the front pads and they seemed to have at least a 1/3 pad left at 78k miles.
__________________
2008 Lincoln Navigator L Limited Edition
2001 Vortech'd Mustang GT
  #4 (permalink)
Old 10-04-2011, 01:55 PM
Ford dealer says its normal because front brakes do most of the braking. I understand that but to have minimal wear on the rear brakes at 73k isn't normal.
  #5 (permalink)
Old 10-04-2011, 02:25 PM
berry1234's Avatar
Quote:
Again, if your not wearing out the fronts at an abnormal rate and the truck stops like it should, what do you want? For them to replace the brakes that are not needed?
__________________
  #6 (permalink)
Old 10-05-2011, 09:18 AM
Only two things I can think of doing as a little home test without taking too much apart is to A) take note on how much brake dust accumulates on the real wheels. Being you have a LTD model I assume chrome wheels as well and should be fairly visible. B) other thing to try is to scratch up the rotor with sand paper and take note on how long it takes for the surface pattern to come back.
__________________
  #7 (permalink)
Old 10-09-2011, 06:17 PM
bjtor bjtor is offline
bjtor is starting off with a positive reputation.
rear brakes
My 2008 Expy just had the rear pads replaced after 23k miles. The dealer said I was within 3k of needing new pads, so I had it done at the recent service. The fronts are still in good shape according to the dealer.
My experience with previous cars has always had the fronts wearing out first (including on my previous Explorer). I realize this is a heavy car, but it seems odd that the rears went so fast. Thanks to the parking brake warning chime, I don't drive far with that on, so I can't blame that!
So either the dealer lied to me (!) or something is not right!
any thoughts?
thanks
  #8 (permalink)
Old 10-10-2011, 12:56 PM
Quote:
Never had brake dust on fronts or rears.
  #9 (permalink)
Old 10-10-2011, 01:08 PM
berry1234's Avatar
Not possible.
__________________
  #10 (permalink)
Old 10-10-2011, 01:18 PM
Ok, let me rephrase that, never had excessive brake dust. Truck gets a bath once every two weeks or so. There has never been a noticeable buildup of brake dust.
  #11 (permalink)
Old 10-10-2011, 03:14 PM
scottmeiners scottmeiners is offline
scottmeiners is starting off with a positive reputation.
scottmeiners
Are you still using the factory pads? How many miles a week do you drive. If I go longer than a week, mine are terrible, it starts to get noticeable on my rims after a day or two.
I had to replace my rears at 40,000. I didn't get to them in time because I assumed it was the fronts starting to squeek and I didn't even look at the rears until it was already into the passenger side rotor.
  #12 (permalink)
Old 10-13-2011, 04:45 PM
TCAS007's Avatar
TCAS007 TCAS007 is offline
2007 Ford Expedition
TCAS007 is starting off with a positive reputation.
Someone told me Les Schwab had decent prices for a brake job. Dis anyone try that? I am undecided if I should work on the brakes myself bot being experienced.
  #13 (permalink)
Old 10-13-2011, 10:10 PM
If you insure...take it somewhere. It's a relatively straight forward job. Done it on the Mustang numerous times, the Expedition when I had it and on the Navi. Just have to take your time and be patient. Can always download the Haynes or Chilton manuals and they should take you through a step by step process.
__________________
Tags
2008, brakes, expedition, expeditions, expidition, ford, navigation, properly, rear, removal, replace, replacing, rotor, system, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
