81 ford f150 ranger 351 winsor poor power and gas mileage - Ford Truck Enthusiasts Forums
Old 10-04-2011, 01:35 AM
81fordf150ranger 81fordf150ranger is offline
81fordf150ranger is starting off with a positive reputation.
i have a 1981 ford f150 ranger 4x4 with a 351 winsor 2 barrel in it... just recently got it running again after replacing the electric fuel pump in the tank.. but it doesnt seem to have the power it should.. tires wont spin, very slow take off, and your lucky if u can get it up to 65 mph.. idles good, and runs good when driving besides the bad gas mileage (about 4 mpg) and the power loss.. any ideas of what could be causing this problem? any help would be greatly appreciated..
Old 10-04-2011, 02:35 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
How are the float level/fuel pressure, & carburetor generally?
Retarded timing will give very lifeless performance along with good starting/idling/running, but 4mpg sounds like carburetor issues.
Old 10-04-2011, 07:22 AM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
Few things wrong here. One, the 351W wasn't offered until 1982. So I'm guessing you mean 351M. And two, F-Series trucks and Broncos didn't get electric in-tank fuel pumps until 1985 on the 302, 1987-1988 on the rest of the engine lineup.
Have you swapped motors in the truck and/or fuel tanks?
Old 10-04-2011, 09:53 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Shaun - You beat me to it, but what else is new? Anyway, he's right - unless there's been some serious swapping, including transmission and gas tanks, it isn't likely that is a Windsor and it won't have an in-tank pump. So, before we diagnose too much let's make sure we know what we are working on because that'll probably make a difference in the solution.
Old 10-04-2011, 11:18 PM
the fuel pressure is pefect and all that. it idles great and runs great it just dont have much power... and the gas mileage is horrible.. havent redone the timeing.. didnt figure it was wrong since it idles and runs fine..and i was told the 2 barrel carburator is whats causing it.. in which i was goin to replace the carb and intake with a 4 barrel. which i dont have the money for right now. so i was goin to order a new holley 2 barrel and hope it fixed the problem. but then i dont want to to that and it not be the problem.. idk how the carburator is or its float levels.. i want to replace it with the holley 2 barrel but i dont want to do that and then find out i do need the 4 barrel.. what is ur opinion there? and no it has a 351W.. and it is the orginal tank, it has 2 tanks... in which only one is in working condition right now.. and no motor swap has been done or any of that..
Old 10-04-2011, 11:32 PM
the way i was told to find out if it was a cleveland or a winsor was that if the ratiator hose runs into the intake then its a winsor.. if it doesnt then it is a cleveland. is this incorrect?
Old 10-04-2011, 11:39 PM
sorry about all the replies but even autozone and oriellys tells me that the truck can come with a winsor
Old 10-04-2011, 11:45 PM
Old 10-05-2011, 03:26 AM
I would eliminate some possibilities, one at a time. You may need a carb, but it's free to check the timing & then you can move to the next thing.
If you want to get running at minimum cost for now, your own carb may well be repairable for just a few dollars or adjustments.
Try to be methodical & pinpoint the problem, or too much money can be lost.
Old 10-05-2011, 11:41 AM
ok. to redo the timing i have to have a timing light, correct? if so about how much do they run?
Old 10-05-2011, 12:58 PM
10-12 degrees btdc as a start, but depending on fuel, compression, your distributor, etc it varies - so I advance until there is a slight ping at full throttle/lower rpm, then retard JUST enough to stop the ping.
This will give you the best power & economy (as far as timing is concerned).
If you have a vacuum gauge on the truck, this setting should pretty much coincide with the highest vacuum reading.
And if you do have a 351w, turning the distributor clockwise ADVANCES the timing.
Old 10-05-2011, 06:38 PM
Gary Lewis's Avatar
While Autozone and O'Reillys may say a 351W came in the '81s, it was the E series vans, not the F series pickups. I have the '81 factory shop manual and it indicates that the vans had Windsors and the pickups had the 351M.
So, how to tell? The Windsor's water outlet is through the manifold in the front, while I've read that the M's is just straight from the front top of the block. Another way is that the Windsor's valve cover has 6 bolts while, if I remember correctly, the M's has 8 - but at least it isn't 6.
I think you have a 351M. And, I hate to tell you but I personally don't think they have much power w/o modification. How do I know? My father has a 1981 F150 Ranger 4x4 with the 351M and I have a 1982 Explorer 4x2 with the 351W. I've driven them back to back and ........ (how to say this w/o offending someone....) stepping on the throttle on the M is like stepping on a dead toad in comparison to doing the same on the W. I know, that's not really fair since mine's 2wd and Dad's has the heavy transfer case. Trust me, there's far more difference than that would account for. Having said that, I dearly want Dad's truck when he's done with it, but that engine has to be fixed.
I say all that to say this - don't expect lots of power from a 351M. However, it should easily cruise at 65 - Dad's does. But, it won't spin the tires unless you are on sand, gravel, or snow. As for gas mileage, you should be getting close to 10 - Dad's does on the highway running 60 - 65 with 3.50 gears.
So, yours should be doing better. The first place to look is as Ken suggested, the timing. You will need a timing light. You can find the cost of one of those on-line. And, it would be good to have a vacuum gauge, which isn't expensive at all. Once you set the timing, check to see what vacuum you are getting at idle. You should be somewhere around 20" or maybe better. Then report back and we can help you from there.
Old 10-05-2011, 07:39 PM
If your truck was built very late in the model year, such as April of 1981 or so, then there is a small chance that it could be a 351 W. However, as Gary suggested, the 351M uses a dry intake, while the 351W uses a wet intake. This is the easiest way to tell. Not to mention, the valve covers are entirely different between the two.
You can't trust what Autozone and O'Reilly's says, because they're not trained to know every little thing about every little vehicle.
Old 10-05-2011, 07:42 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Yes, 8 bolts on the 351M, 351C and 400 valve covers.
Another way to tell - the M will have two vertically-oriented bolts holding on the fuel pump, it's the only Ford engine to have that configuration.
Old 10-05-2011, 08:30 PM
Gary Lewis's Avatar
Speaking of Autozone and O'Reillys, you may be able to "rent" a timing light from them. The way their rental program works, at least O'Reillys, is that you pay for the tool but if you return it w/in 48 hours you get all your money back. I've used it several times for things like pulley pullers.
2001 E450 7.3L uncommon no start Volkskid 1999 - 2003 7.3L Power Stroke Diesel 9 10-13-2014 09:25 PM
1994 E150 351, low voltage to fuel pump perch57 Arizona Chapter 7 08-16-2012 12:42 PM
Air In Fuel Lines HELPPPP 6.9 IDI seancrawford14 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 02-29-2012 10:09 AM
5.0 Fuel Pressure - Delivery Problem 73FOMO Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 12-16-2010 09:05 AM
This blinker mod really works!! muleguitar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 26 01-04-2010 10:05 PM
Tags
1982, 351, barrel, block, f150, ford, gas, idles, milage, mileage, mpg, pick, power, ranger, small, starts, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
