F250 and best recommended engine oil - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-03-2011, 11:41 PM
mauser6818 mauser6818 is offline
mauser6818 is starting off with a positive reputation.
For all, please give me some advice. I realize this topic will be highly controversial due to brand loyalty etc....here is the scenario; I am buying a used 1999 F-250 XLT with a 5.4 Triton. The truck has had the engine replaced about 50 K ago with another 5.4 Triton and Ford doing all of the re-install on the motor. Underneath this thing is as dry as a desert! NO Leaking, etc. I have test driven the truck, it is smooth as silk,motor sounds great and everything appears in fantastic working order. With that said, the one thing that was a "bummer" for me was the fact that the owner was using Pennzoil 10-30 in the truck since the motor was replaced. He has been good about regular oil changes, so with that being the case, even though Pennzoil was his oil of choice I'm sure it is o.k. being that changing it regulary is the most important thing. However, Penzoil is NOT my personal choice at all. I wonder what the opinion is regarding changing oil brands with a higher mileage engine like this..will it hurt anything?... and what would be the best recommended weight/ viscosity for the 5.4 Triton? Would switching to a full synthetic like a Mobil One be a good choice over the conventional? Please feel free to weigh in.
Thanks
Old 10-03-2011, 11:47 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
I used Motorcraft 5W30 with a Motorcraft filter in my 5.4.
Old 10-04-2011, 12:28 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
First off welcome to FTE. Enjoy your stay.
Second, there is no "best" as many people will try to tell you otherwise. However, many of us have favorites. Personally I am running Shell Rotella full synthetic. Amsoil, and Chevron are also popular brands. I have also run the Motorcraft oil with success.
My best advice is dont listen to us, listen to your truck. Try a few different oils and see how your truck responds. You will be surprised how much your truck can tell you. Using a Blackstone Labs test kit you can get a detailed oil analysis that will tell you everything you need to know. Thats not necessarily, but good for the truck owner who cares. Try 3 or 4 different brands changing at 5000 miles until you find the oil you and your truck agree upon. A full synthetic will be better for your truck, but a normal oil like the Motorcraft oil will also be just fine. In my opinion no single oil is the best, but rather each truck is just a little different in its tastes. See what your truck likes.
Also, as far as filters go, I would stick with Motorcraft oil filters. They seem to be at or above par most of the time.
What is the Best Gear Oil to use? sirkingdra 1999 to 2016 Super Duty 13 10-28-2016 09:56 PM
Is Pennzoil synthetic any good ? 2000F-150XLT Oil & Lubrication 18 06-30-2016 08:54 AM
5.4 liter Triton, any good? oft 2004 - 2008 F150 17 03-12-2015 01:55 AM
pennzoil high-milage vs pennzoil synthetic blend? racsan Oil & Lubrication 1 02-17-2014 11:14 PM
Whats your oil of choice? cb_13 Oil & Lubrication 107 01-23-2014 07:31 AM
Tags
2000, 2001, 54, diesel, engine, f150, f250, ford, motor, oil, recommended, rercommended, triton, trucks, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
