Vibration at 45-50 - Ford Truck Enthusiasts Forums
Vibration at 45-50
Old 10-03-2011, 10:33 PM
ZChavira ZChavira is offline
ZChavira is starting off with a positive reputation.
Vibration at 45-50
i have an 04 f-150 supercrew 4x4 lariat with 103k miles that has a pretty bad vibration between 45-50 after it switches into overdrive, when you turn overdrive off the problem goes away. ive taken it to the dealer and they put shutter guard in it an said to let it work through for a couple hundred miles. it still hasnt gotten any better, does anybody have any idea what it is?
Old 10-04-2011, 10:33 PM
JoSHN JoSHN is offline
JoSHN is starting off with a positive reputation.
Sounds like a torque convertor having an issue locking/unlocking.
Old 10-05-2011, 08:26 AM
How do you go about fixing something like that?
Old 10-05-2011, 10:33 PM
If it is the TC, you would go about it by dropping the transmission, and replacing the TC.
Depending on your garage set-up, this is either a simple to mild task..... or a massive PITA.
Driveline Vibration Bradlyw 1999 to 2016 Super Duty 11 06-03-2013 08:33 PM
Shutter at 45-50 ZChavira 2009 - 2014 F150 2 10-05-2011 12:00 AM
Vibration in overdrive selbona 1987 - 1996 F150 & Larger F-Series Trucks 4 06-30-2010 09:09 PM
Triton V8 engine sputter at 45-50mph Knlpetty 1999 to 2016 Super Duty 1 07-09-2008 05:10 PM
2001 F250 4x4 v10 kid is gone 1999 to 2016 Super Duty 5 09-05-2003 11:41 PM
Tags
45, f150, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
