EGR Valve Removal 1997 Ford Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-03-2011, 08:48 PM
kdwyer kdwyer is offline
kdwyer is starting off with a positive reputation.
Need some guidance in the removal of EGR valve on a 1997 Ford Ranger 2.3L engine. 4 cyclinder.
There is a pipe with 1 1/16 inch hex head (approximate) that is threaded into the EGR valve. Anyone know specifically how to break it loose? There is minimal clearance to get a regular wrench in there to get a good grip. Is there a special tool or device that works best? Anyone have any experience with this particular EGR valve removal. Any tips would be greatly appreciated. Thank you in advance.
Old 10-04-2011, 11:55 AM
mjshagnasty's Avatar
mjshagnasty mjshagnasty is offline
mjshagnasty is starting off with a positive reputation.
Ratchet crescent wrench???
Old 10-04-2011, 02:12 PM
Too big of a wrench. No clearance. Ratchet will not work.
Old 10-04-2011, 05:06 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
Crows foot socket with 1/2" drive?
Old 10-04-2011, 08:03 PM
Thanks ranger pat. That is what i was thinking. Have you had to replace your egr valve? Was that the tool you used?
Old 10-05-2011, 12:00 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Are you certain you need to remove or replace your EGR? What is your reason or code?
Old 10-05-2011, 08:59 AM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
MikeB 88 is gaining momentum as a positive member of FTE.
I replaced mine just a little while back. Yes, it wasn't easy to get the wrench in there, but after working at it for a bit I found a way. I just can't remember how I did it.
Check Engine Light on '92 2.3L Ranger - Code 327, 328, and 334 Pad2383 Ranger & B-Series 2 05-11-2013 09:07 AM
EGR valve MikeB 88 Ranger & B-Series 9 07-19-2010 08:01 PM
EGR valve smoke leak jlutes Ford Inline Six, 200, 250, 4.9L / 300 5 04-29-2009 11:00 AM
Help EGR! v joncas Ontario Chapter 1 08-06-2004 08:34 PM
egr valve location for 8 cylinder ford explorer rcftx Explorer, Sport Trac, Mountaineer & Aviator 2 04-20-2004 09:19 PM
Tags
1997, 46, 96, code, cyclinder, egr, eng, ford, list, liter, location, ranger, replace, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
