Frame Straightening... - Ford Truck Enthusiasts Forums
Old 10-03-2011, 07:51 PM
TheRooster12 TheRooster12 is offline
TheRooster12 is starting off with a positive reputation.
I have a 71 f100. The bed on my truck was rotted. It had a sheet of plywood bolted in and a some corrugated aluminum screwed to the top. It seemed to sit really low at the rear. So, after a long search, I found a great donor bed from a 72. I swapped the beds and noticed that the new bed sat the same way... I experimented and shimmed it up. It took an inch and half on the passenger side and two inches on the driver side to get it into the right alignment. I quickly realized the frame was bent... Does anyone know approximately how much it would cost to straighten the frame? Or, is it just better to leave it for now and look for a new frame to swap the whole truck on to? Thanks
Old 10-03-2011, 10:02 PM
akforceten's Avatar
akforceten akforceten is offline
akforceten is starting off with a positive reputation.
I would swap frames or just find another truck .
Old 11-21-2011, 05:59 AM
Thipdar's Avatar
Thipdar Thipdar is offline
Thipdar has a good reputation on FTE.Thipdar has a good reputation on FTE.
There was a time, years ago, when I took the F250 in for an alignment... and the guy refused.
He said one of my I Beams was tweaked, and that it would have to be straightened before he would work on it.
He told me to take it to a place a couple of towns over where they specialize in straightening the frames for SEMIS.
Find yourself a frame straightening shop and get a quote. Whatever price I could tell you wouldn't apply and would be stale anyhow.
Old 11-21-2011, 07:13 AM
60F100 60F100 is offline
60F100 is starting off with a positive reputation.
To bad you aren't near Florida, I have a good 69 F100 frame and a good 71 F250 frame sitting in the yard that will probably be cut up for scrap.
Old 11-21-2011, 10:00 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
I would get a quote from a frame shop first. You never know may be far less than all the effort required to swap frames. Putting the frame back in line is not that big a deal to the guys with the equipment.
Old 11-21-2011, 11:48 PM
TaborCT's Avatar
TaborCT TaborCT is offline
TaborCT is starting off with a positive reputation.
im on the frame swap from a donor. find a 73-79 model and that way you can get the front disk brakes as well. be better bet in the long run and save you money in the long run when it come to making the truck safer/modernized
Old 11-22-2011, 07:51 AM
elgemcdlf's Avatar
I did a body swap some years ago. It took 40 hrs and that was done in a shop with a lift & air. I would think just getting the original straightened if the expense is not excessive would be well worth it. There really is not much difference at all as far as modernization goes. The rear axle & spring mounting is 4" wider giving more stability. That is all you would gain for all your efforts.
1951 F2 frame issues 682bear 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-08-2016 12:38 AM
Bent frame IHateCommieCars 1999 to 2016 Super Duty 4 04-26-2016 08:52 AM
Straightening bed front, anyone ever done it? FordMaverickFan 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-31-2012 04:30 PM
bent frame channel where hitch attaches...advice..? 05victorylly 1987 - 1996 F150 & Larger F-Series Trucks 10 03-08-2012 09:52 PM
Frame swap? 72-74 Rogue_Wulff 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-23-2011 04:59 PM
Tags
150, 1972, 1999, 2006, average, blueprints, cost, f150, f350, ford, frame, ram, straighten, straightening, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
