Making my Schematics for modifications
Well, with all the mods and updated for this winter, I am starting to get the ducks in a row.
I just finished a wiring diagram for the modifications in and on the F650 dash.
The ACR switch is a Automatic charging relay for the multiple battery install. Blue Seas 7622
The file in pdf form is at the link below.
Let me know what you think. I hope that others will be able to use it for ideas.
Edit: All electrical diagrams are essentially done. The full list below:
sheet 1.pdf - PDF Archive
sheet 2.pdf - PDF Archive
sheet 3.pdf - PDF Archive
sheet 4.pdf - PDF Archive
SHEET 5.pdf - PDF Archive
SHEET 6.pdf - PDF Archive
Next up is under the hood...
I just updated the PDF file. I added diodes to allow both compressor switches to act as master on the air locker switches at the same time, and not turning both compressors on at once.
When I do the air line layout both air systems, the air lockers and the main system, will be hooked together, but it will have a check valve in the main line going to the air lockers. that way either system will operate the lockers, but the little compressor will not be trying to fill the air tanks.
Well, I got the preliminary Main power distribution bus diagram is ready. This is all under the hood.
Ended up making some changes to the dash wiring. I updated that link.
Here is the second sheet:
http://www.pdf-archive.com/2011/10/12/sheet-2/
When I do the air line layout both air systems, the air bags and the main system, will be hooked together, but it will have a checkvalve in the main line going to the bags. that way either system will fill the bags, but the little compressor will not be trying to fill the air tanks.
I take it you're going to run two compressors and tie the supply lines together. What will keep the bags from reaching tank pressure if the big compressor is running? Will your Air Up switch control a solenoid to feed the bags?
Yes it will be using air valves on the bags.
As far as the plumbing, that will be on sheet 4. (edit make that sheet 5 or 6)
I'm starting sheet 3 now, which has all the primary wiring for lights, compressors, etc.
Yes, I am making my own cables. Crimped using the cheap tool below and a 20 ton shop press. I hate hammering..
I've done it a couple of times with this setup before for my trailer. Works well.
This is all in the planning stage right now. I do all my major upgrades in Dec-Jan each year when I get the cash to do them. This is gonna be a big one this year. There is several things planned aside from all this electrical The axles are gonna get all new shafts and hopefully a Dynatrac spindle kit, new brakes/rotors/calipers, new ujoints all around, and all new steel braided lines.
Got some very light rust issues forming underneath, and those will be taken care of too.
Next year will be all the engine/exhaust/interior mods I am drooling to do.
All sheets updated.
2 new sheets made showing most of the primary wiring
Still need to do the pneumatics sheet and final wiring sheet
All electrical sheets now essentially done.
EDIT: Looks like sheet 2 is in major flux. I have a lot more reading and study to do to finalize it. will update when ready. 10/27/2011
Now for the pneumatics.....
78fordbeast
10-04-2014 09:06 PM
BluesManF250
02-25-2004 02:46 PM
