Inner Tie Rod Removal Tool, None Fit!
Hey Guys,
Im trying to replace the inner tie rods on my wifes 2003 navigator. All 3 tools I have tried either 1)dont have a large enough hex, 2)have too shallow a shoulder to fit over the inner tie rod to reach the hex.
What the hell? Does anyone know of a tool that actual will work on this truck?
Also can the upper and lower ball joints be pressed out of these control arms and replaced or do I need to order entirely new ball joints?
I just replaced the inner tie rod ends on my 98 Expe. I bought a removal tool from Autozone and instead of popping out the bolt, the tool spread apart. I then used a torch to heat it and punched out the bolt with a hammer. It came out pretty easy then. As for the ball joints, I had the control arms replaced my last inspection. I like to do my own work, but I was told the ball joints had to be pressed in/out. It was a rare time when I just paid someone else to do the work.
Found a way!
Hey Guys,
LiftdFord
12-11-2009 10:08 AM
