Inner Tie Rod Removal Tool, None Fit! - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 10-03-2011, 07:01 PM
EriKU19 EriKU19 is offline
EriKU19 is starting off with a positive reputation.
Hey Guys,
Im trying to replace the inner tie rods on my wifes 2003 navigator. All 3 tools I have tried either 1)dont have a large enough hex, 2)have too shallow a shoulder to fit over the inner tie rod to reach the hex.
What the hell? Does anyone know of a tool that actual will work on this truck?
Also can the upper and lower ball joints be pressed out of these control arms and replaced or do I need to order entirely new ball joints?
Old 10-04-2011, 08:35 AM
Icefan71 Icefan71 is offline
Icefan71 has a good reputation on FTE.Icefan71 has a good reputation on FTE.
I just replaced the inner tie rod ends on my 98 Expe. I bought a removal tool from Autozone and instead of popping out the bolt, the tool spread apart. I then used a torch to heat it and punched out the bolt with a hammer. It came out pretty easy then. As for the ball joints, I had the control arms replaced my last inspection. I like to do my own work, but I was told the ball joints had to be pressed in/out. It was a rare time when I just paid someone else to do the work.
Old 10-04-2011, 09:25 AM
I fish's Avatar
I fish I fish is offline
I fish is starting off with a positive reputation.
Quote:
I did mine back in the spring. on my '98 i pressed thelower ball joints out and new ones in with the tool i borrowed from Advance Auto. I replaced the entire upper arms, as my understanding was you can't replace just the ball joints in the OEM upper, but that next time i should be able to with the aftermarket Moogs I installed
Old 11-14-2011, 08:14 PM
wspastorbryan wspastorbryan is offline
wspastorbryan is starting off with a positive reputation.
Are these a normal maintenance issue? The inner tie rods don't look like they would need to be replaced like a ball joint would. Seems like they get less wear.
Old 03-29-2014, 02:55 PM
Gman_74 Gman_74 is offline
Gman_74 is starting off with a positive reputation.
Found a way!
Quote:
Originally Posted by EriKU19 View Post
Hey Guys,
I had bought a ford fan clutch wrench set that they sell at auto stores. It happens to be the same size hex. I was able to fit it in there and hit it with a hammer to break it free.
Old 04-01-2014, 09:36 AM
showags showags is offline
showags is starting off with a positive reputation.
I have two lisle inner tie rod tools. They sell a standard and a large. The large works on my 2005 Expy. I've found it's just as easy to get under the truck and use a large wrench on the hex too. I have done it both ways.
Inner tie rods - got2bjoester Escape & Escape Hybrid 1 12-19-2016 09:50 PM
Tie rod ends and ball joints tools ligito 1999 to 2016 Super Duty 9 05-22-2015 06:54 PM
Inner tie rod torn dust boot Outspoken1 Ranger & B-Series 4 03-07-2015 05:05 PM
Tool for inner tie rod Beaned Aerostar 10 08-25-2004 09:26 PM
I'm going to change my upper and lower ball joints, How hard? mnm99 1978 - 1996 Big Bronco 3 04-09-2003 01:33 PM
Tags
03, 2003, 95, autozone, end, explorer, ford, navigator, replace, replacing, rod, rods, tie, tool, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
