help 4.6 and no power - Ford Truck Enthusiasts Forums
Old 10-03-2011, 06:56 PM
ampslw ampslw is offline
ampslw is starting off with a positive reputation.
hello to all
Im help a buddy out with f150 97 4.6 it is running real bad it has a hesation and no power up hill
is also spiting out codes
p1409
p0171
p1000
i put a new fuel filter in to day
i also cleaned the map sencer
Old 10-03-2011, 07:00 PM
also
the fuel psi stay around 30 to 33 psi if i un plug the fuel pressure reg it will go to 40 psi slowly
air filter is clean
shouldn't it be 70 to 100 psi
Old 10-04-2011, 12:29 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
You have to learn not to guess at anything on these computer controlled engines.
No, the fuel pressure is not anywhere near 100 psi in the fuel rails. It's more near what you saw on your gage.
Next, the 1409 code is specifically an EGR vacuum regulator fault.
It's either unplugged, open or stuck.
If stuck open it has the EGR open full time and this will cause a drivability issue.
The 1000 code is not a fault code but an indication the system has not passed all 7 system tests.
The code 1000 will clear once all 7 monitors are reset by finding no faults.
The 171 code might be due to the EGR regulator fault (1409).
Clear the 1409 then see what you have after you clear the codes and drive it for a new code history.
Then clear what comes back.
This way there is less confusion about what you have going on.
Good luck.
Old 10-04-2011, 10:05 AM
more info added
P0171 System Too Lean (Bank 1)
Freeze Frame for DTC P0171 Fuel System Status Bank One Closed Loop Fuel System Status Bank Two Not Reported Calculated Load 42 %
Coolant Temperature 199 F
Short Term Fuel Trim Bank One -3.90 % Long Term Fuel Trim Bank One 14.82 % Short Term Fuel Trim Bank Two 5.46 % Long Term Fuel Trim Bank Two 7.80 % Engine RPM 1216 r/min Vehicle Speed 30 MPH Enhanced Powertrain
P1409 EGR Vacuum Regulator Solenoid Circuit (See P0403)
P1000 OBD Systems Readiness Test Not Complete Anti-Lock brakes
im using AutoEnginuity OBD2 i have cleared the the codes and did koer test and they will come back time after time
to day i heard a noise after i turned off the truck i could hear a sweak under the hood .
the sweak was comming from the egr line ( white tube ) were it hooks up to the green line at the silanod. i also clean it out very dusty
Old 10-04-2011, 01:33 PM
You have the same info I gave you except an indepth rundown to support the reason for the code 171.
For the vacuum regulator, remove it. Take the round cap off. A spunge filter will be found.
Clean it and spray clean the valve inside to be sure it's free.
The noise you hear is air going back 'into' the EGR to release it. This is why the motor runs so poorly. The EGR is open full time when it should not be.
It's repair time. Do it to it.
I don't know what you brake issue is but if you have no ABS lamp, let that go to last.
Do the work, then lets hear how it ends up.
Good luck.
Old 10-04-2011, 04:09 PM
ok here we go
i have cleaned the valve inside to be sure it's free
i have also check for vac leaks and made shure all of vac lines are free
now when i run a koer test all i get is
p1000
p1408
the hezation is still there but better
Old 10-04-2011, 08:00 PM
Have you noticed the first code you gave was 1409.
Now you give 1408.
Both are for EGR operation.
The 1408 is very close to a 401 code.
You have the truck to work on. We cannot tell you exactly what to put your hand on as the hardware trouble.
Possible there is/was more than one issue at the same time.
Work on it to find it, same as anyone else would have to do.
Look up the codes, find out what the test is, that fails.
You have hoses, EVR, EGR, DPFE, and the metal tube between the exhaust manifold and the EGR. All could be a source of a flow failure.
The 1408 code tells you the flow the PCM expected was too low.
The test routine opens the EGR a specified amount by pulsing the EGR to allow flow.
The DPFE measures that flow and reports it to the PCM for comparison to a table. If the value reported is out of limits [for any reason] according to the table match, it's considered a fault and sets the code.
Could be the ports behind the EGR are nearly plugged shut.
There is nothing much more to tell about it.
Good luck.
I have a P0453 error code on F150 4.6 - need help nitro94 1997 - 2003 F150 10 12-27-2014 06:27 PM
P1121....please help solve the mystery Gibby speed 1997 - 2003 F150 3 01-20-2010 06:58 PM
Error Code P-2601 brywood Modular V8 (4.6L, 5.4L) 4 09-29-2007 11:01 PM
Engine Codes shultzy501 1997 - 2003 F150 7 02-11-2005 11:20 PM
codes P0172 and P0175 darkris Modular V8 (4.6L, 5.4L) 1 10-14-2003 12:21 AM
Tags
03, 1409, 2003, 46, 97, code, expedition, f150, ford, low, p0403, p1409, power, rpm, truck, whatis1409codeforfordexplorer199950v8feedbackhoseo fforpluged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
