engine choice 5.0 or 5.8
Old 10-03-2011, 02:23 PM
blacklab1's Avatar
blacklab1
blacklab1 is offline
I'm looking for another truck one choice has a 5.8. Is there a signifigant difference in gas mileage between the 5.0 and the 5.8.
Which of the two engines would others choose? Looking for opinions and pro and con.
Old 10-03-2011, 02:25 PM
86F150302's Avatar
86F150302
86F150302 is offline
Ive had both. Ill take the 351
Old 10-03-2011, 03:14 PM
Conanski's Avatar
Conanski
Conanski is offline
Unless you're just looking at a 2wd reg cab for a commuter get the 5.8, there ain't enough difference in fuel milage between the two motors to make it worth short changing yourself an a real truck engine.
Old 10-03-2011, 03:30 PM
preppypyro's Avatar
preppypyro
preppypyro is online now
Ive experienced both, although one was a carbed 5.8. (1986 model truck)
The carbed 5.8 got terrible fuel mileage, and it was a ford factory reman engine.
I get much much better economy with my 302 truck. (2wd, 308 rear diff, 5 speed reg cab reg box) Reliability of the 351 we used to have was poor, hence the factor ford reman engine, and it left a poor taste in my mouth .
Real truck engines dont have spark plugs my friend
Old 10-03-2011, 03:31 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
I agree...(at least for a 2wd application...stroke a 5.0, use the late 90's EFI heads, headers and plenty of air...1986 F250 circa)...put a ZF 5 speed in back of it and 3.73 gears. I can outpull both a 300 6 and 5.8 and I also get 22mpg(not bad for a speed density motor)...For heavier duty applications, I love my 7.5 stroker...the 5.8 is a good in between motor but the fuel milage sucks (Once again, just my opinion based on 20 years now of running EFI trucks, and carb is definately different...not to mention 4wd applications)>
Old 10-03-2011, 03:38 PM
fast58's Avatar
fast58
fast58 is offline
There's no replacement for displacement.
Old 10-03-2011, 03:40 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
except fuel milage (3.59 a gallon up here means you can't go far with displacement)!!!
Old 10-03-2011, 03:55 PM
blacklab1's Avatar
blacklab1
I'm looking at several different trucks, all 4x4s. I haul a small camper sometimes, but mostly local hunting, fishing trips.
Old 10-03-2011, 03:57 PM
Edgethis's Avatar
Edgethis
Edgethis is online now
5.8 all the way. He's talking stock for stock. Of course a stroked and modded 302/347 "might" out pull a stock 351. But that's apples to oranges.
Old 10-03-2011, 04:01 PM
Chris72's Avatar
Chris72
Chris72 is offline
5.0 I have owned several of both. Unless your hauling big trailers, the 5.0 will get you where you want to go.
Dont get me wrong the 351 is not a bad motor, But both of them ( EFI ) that i have owned got really poor fuel mileage compared to my 5.0 . All were automatics with overdrive so I am comparing apples to apples.
Old 10-03-2011, 04:11 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
AMEN!!!!
Old 10-03-2011, 04:39 PM
SCRebel's Avatar
SCRebel
SCRebel is offline
5.8, doesn't work as hard to move the truck as the 5.0
Old 10-03-2011, 05:21 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
ill never own another 302. slow and bad mileage. misewell be fast"er" and get bad mileage.
Old 10-03-2011, 05:46 PM
lew52's Avatar
lew52
lew52 is offline
It all depends on the years , i would rather have a 95 302 than a 85 351 , i also would not want a 85 302 , the smog motors just suck what ever you have ...The 94 up motors are just better....Lew
Old 10-03-2011, 07:00 PM
ravens fan's Avatar
ravens fan
ravens fan is offline
ive experienced both and neither get good gas mileage so why not get the one with more power...id say go 351!
Quick Reply: engine choice 5.0 or 5.8
