Heater not blowing hot - Ford Truck Enthusiasts Forums
Old 10-03-2011, 01:17 PM
saxtonj's Avatar
saxtonj saxtonj is offline
saxtonj is starting off with a positive reputation.
I have a '78 F150 Explorer with 400 and factory A/C.
My heater won't blow hot air, it will blow lukewarm/room temperature at best. The fan is working fine. I have hot water coming into the firewall and return hose gets hot too. Is there a vacuum operated door or something that I should suspect? Heater has worked great for the past 33 years.
Any ideas?
Old 10-03-2011, 02:24 PM
SCRAPHEAP51's Avatar
SCRAPHEAP51 SCRAPHEAP51 is offline
SCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to behold
Maybe the heater core is partially blocked, maybe only a few tubes free to allow flow thus only getting warm and not hot? What about the levers operating the doors are they free and working? just guessing here.
Old 10-03-2011, 04:13 PM
starwriter starwriter is offline
starwriter is starting off with a positive reputation.
I can think of a few things it could be.
1) You can reverse the heater hoses believe it or not, I didn't at first. You may need to switch them.
2) There is a cable running from your temperature slide/switch on the dash to a vent. This can come unhooked and allow very little warm air into the cab.
3) Surrounding the heater core is some weather stripping, it breaks down over time and allows air to flow around instead of through the heater core.
Old 10-03-2011, 04:19 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
id say its the door that directs the air over the heater core.. its controlled by the temp slide. Its not easy to get to.
Old 10-04-2011, 08:06 AM
saxtonj's Avatar
The temperature slide moves good with slight resistance which might indicate that the cable is not off or broken and is still working a door or something.
I will try changing the hoses first, but if that doesn't work I guess I will have to pull the under dash unit and perform exploratory surgery...
Heater not blowing hot/ engine stays cold BlG_dunk95 1994.5 - 1997 7.3L Power Stroke Diesel 4 10-04-2016 09:01 AM
1993 f150 heater problems superman7928 1987 - 1996 F150 & Larger F-Series Trucks 6 01-30-2015 03:08 PM
heater not working at idle jwheatley20 6.0L Power Stroke Diesel 36 11-15-2013 05:51 AM
Heater not blowing hot TWolf 1978 - 1996 Big Bronco 16 12-17-2004 03:49 PM
Rear heater core?? Cobra150 Excursion - King of SUVs 1 10-28-2004 11:21 PM
Tags
79, blows, ford, heater, hot, room, temp, truck, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
