5.4 randomly misfiring - Ford Truck Enthusiasts Forums
Old 10-03-2011, 01:58 PM
C&W Auto and Diesel C&W Auto and Diesel is offline
C&W Auto and Diesel is starting off with a positive reputation.
Hey guys, great looking forum you have here. I have a 2005 5.4 F-150 I am working on for a customer and am looking for a second opinion as to what the problem with it might be. First off it came to me on a rollback because the owner tried to replace his plugs after he noticed it missing and of course broke one off. So after I extracted the plug from #8 cylinder and installed a new plug I cranked the truck and it was idling very rough and had a terrible miss around 1200rpm. I pulled the codes and got several misfire codes and ignition coil faults on #5,6 and 7 cylinder. Popped in 3 known good coils in these 3 cylinders with no difference. On Mode 6 on my diagnostic software you could watch the misfire count steadily increase on #7 and every now and then there would be a single misfire on #5 and 6. It also had several codes for O2 sensors biased, stuck rich on that bank. Well since it had a brand new plug and coil, I popped an injector in #7 and havent had a single misfire on it since and it also started idling alot better and all the O2 codes went away. The problem I am having now is #5, 6 and now 8 will randomly misfire, sometimes build up a steady count on one of them, sometimes just skip around between them. The truck has brand new plugs in all 8 and new coils on this bank also. The truck has 115,000 on it and does have some cam phaser noise on the bank causing the problem, but its not too terribly bad, I have heard alot worse. My problem is something on that bank only as the passenger side bank is fine. I am wanting to say cam phaser now since this is the side with the noise. I have changed them before but have just experienced the noise, never one running like this because of it. Possibly jumped time a little? Has anyone seen this? Any ideas would be appreciated. Sorry for the extremely long post.
Old 10-03-2011, 02:14 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
What kind of plugs did you use in the truck? These trucks seem to fight with everything except Motorcraft plugs. Also when installing the new ones don't forget the anti-seize on the plug ends.
I really don't think the cam phasers are causing the idle problem you are having. I haven't read about them doing that before so would start to look else where first.
What else has been done to the truck recently? Fuel filter, throttle body, and etc...
Old 10-03-2011, 02:19 PM
He replaced 7 of them with Motorcrafts and broke the last one he had left and thats when it was brought to me and I extracted the plug and replaced it with the Motorcraft he had left. He is an elderly man and said he has never had any trouble out of the truck until he noticing it missing and he figured it needed a set of plugs, and so the story goes from there.
Old 10-03-2011, 02:22 PM
Also I see a pretty good bit of these trucks and do the typical injectors and coils and alot of the cam phasers before the local Ford dealers started taking care of them. Also i go around to alot of shops and peoples houses extracting plugs so I pretty familiar with these I have just never seen one act like this.
Old 10-03-2011, 10:40 PM
1bad67sbf's Avatar
1bad67sbf 1bad67sbf is offline
1bad67sbf is starting off with a positive reputation.
what about the VCT solenoid
Old 10-03-2011, 11:42 PM
iilijah iilijah is offline
iilijah is starting off with a positive reputation.
If it makes you feel better, I just changed my plugs also. Right off the the back I had cyl4 misfire. Turns out I got a bad plug. The first thing I would do is replace the new plugs with some newer ones and go from there. Swap the coils, put the ones that are on the bank that's misfiring and put them on the other side of the motor. If you just go changing a bunch of things you may as well just be throwing away money. 4 new plugs only set me back 38 dollars and I only needed the one. But well worth the investment.
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Make sure he used the correct Motorcraft plugs. I had a similar problem on an Expedition 2006 5.4L 3V. The wrong motorcraft plugs were used. Replaced using the correct SP507 plug and misfiring stopped.
Old 10-06-2011, 10:28 AM
soo ford soo ford is offline
soo ford is starting off with a positive reputation.
I had my 2006 F150 5.4 put on the scanner P0018 the computer indicated that Bank 2 had a cam problem .. idling ruff and mech said it was out ot of timing on that side.. any advise out there..
Old 06-18-2014, 10:09 AM
Wright460 Wright460 is offline
Wright460 is starting off with a positive reputation.
Unhappy 2007 5.4 misfire
I've been reading all the posts I can about this problem and have noticed that no one has a definite answer to this problem. Plugs, coils, boots, head leaks etc. and the problem still seems to come back with everyone.
I really appreciate all the posts but is there one answer to this very common problem to fix it. We all have the same symptoms and there has to be one answer to this.
Please help, just totally frustrated!
Old 06-18-2014, 11:51 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The most common cause of misfires is worn spark plugs. When the plugs are worn the gap is wider so it takes more voltage to jump the gap. The coil can only put out so much so if the required voltage is greater than what the coil can produce then it doesn't fire. Sometimes the voltage finds it's way outside the plug between the plug and boot and the spark goes outside the plug to ground. This causes carbon to form where the spark passed and the carbon acts like a conductor so now there are 2 paths for the spark, through and around the plug. Electricity take the path of least resistance so when you are cruising in overdrive at 45 mph then the PCM leans the mixture and advances the timing for best fuel economy but what that does is makes it harder for the spark to go where it needs to so it goes outside the plug and boom, misfire.
Old 06-18-2014, 12:05 PM
David7.3's Avatar
David7.3 David7.3 is online now
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
If there is any leakage of spark, it can be identified easily by the carbon tracking down the plug, I had a cam phaser fail and gave me random misfire codes only, be careful you have noise on that bank and thats not a good thing. Dave
Old 06-23-2014, 11:40 AM
melbyej melbyej is offline
melbyej is starting off with a positive reputation.
I'm ready to scream about this problem! I live in a smaller town (16,000) and know 5 other guys with very similar problems with the same truck. Terrible misfiring going on, and has for years. I have a '06 and have replaced the plugs 4 times now, with coil packs here and there. Tonight we're going to replace all of the coil packs in hopes that changes it. Should we hit new plugs, boots, and injectors as well just in case? I don't want to keep throwing away money.
For those that aren't aware of the problem, aside from the rough idle when going 55 mph on the highway, around 1200 rpm going up a slight incline, or hill..it starts chugging bad. Shutting overdrive off, and kicking down helps, but is terrible on the fuel economy. At one point it plugged my left cat, so I had a guy cut the cats off, burn the crap out, and put them back on. Will be getting new cats now, as it sounds like crap.
Either way, this was supposed to be my "buy it new, own it forever" truck, and if I can't get this problem fixed this summer I'm dumping it.
Also, has Ford corrected this in their 08-09 trucks? Reason I ask is I have a brand new topper, and it will fit those years. So effing sick of this recurring problem!! Any help is appreciated. I know there's a ton of us out there with this problem, and if I call my local Ford garage they play dumb like it's news to them. Yeah right.
Thanks in advance!
Old 12-21-2014, 08:42 AM
Darrylcc66 Darrylcc66 is offline
Darrylcc66 is starting off with a positive reputation.
thoughts
Quote:
I am having the same problem. When I connect my code reader and clear the codes it seems to correct. This indicates to me it's electronic. Going to do some more research. I have a K and N air filter. Will clean that first and will check fuel filter
Old 11-23-2015, 01:19 PM
009to090 009to090 is offline
009to090 is starting off with a positive reputation.
Cool
Nope, the Misfire issue is still present in my 2008 F250 with the 5.4l 3-valve. It just started at 162k miles., but I had bought the truck used 2k miles ago. It ran like new for 2k miles I owned it, then I noticed a slight stumble (cyl missing) while slowly pulling out from a stop sign. It cleared up as soon as the engine got to 1500-2000rpm. But it set a code. P0304 - CYL 4 MISFIRE.
I'm gonna try swapping coil packs to see if misfire moves. If the misfire does not move, I'll test the injector before attempting pulling the plugs. I gotta be ready and borrow an extractor before I try that.
Old 11-25-2015, 08:32 AM
F150Torqued's Avatar
F150Torqued F150Torqued is offline
F150Torqued has a good reputation on FTE.F150Torqued has a good reputation on FTE.
@David7.3 I agree that close inspection of misfiring plugs can reveal carbon tracking down the ceramic (if the arching over is occurring above the threads). But, your handle prompted me to take a look-see at your profile. Aren't you on the wrong forum here?
2005 5.4 Triton 3V misfires kbwford 1997-2006 Expedition & Navigator 27 Yesterday 01:30 AM
stalling problem on 06 f250 gas zephyrprime 1999 to 2016 Super Duty 22 01-20-2017 06:57 PM
stalling problem on 06 f250 gas zephyrprime Modular V8 (4.6L, 5.4L) 0 12-21-2016 12:20 PM
'98 Expedition 4.6 Random Misfire ctown2 1997-2006 Expedition & Navigator 44 06-24-2016 09:09 PM
2008 misfire diagnosis help? Arctic AL 2004 - 2008 F150 1 03-23-2016 07:30 PM
Tags
1, 2006, 2008, 3v, 54, body, coil, expedition, f150, ford, ignition, misfire, module, p0018, plug, random, throttle, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
