1992 f150 msd distributor swap NEED SOME HELP!!!
Old 10-03-2011, 09:19 AM
Mark57Lee's Avatar
Mark57Lee
Mark57Lee is offline
hopefully the title grabs enough attention lol its not that big of a deal. but this is unframiliar territory so i need some help. in a previous thread i had some coil problems so i'm just gonna step up the distributor to an msd and eventually a 6al etc. basically where i need help is finding out if the 87-93 5.0 distributors by msd will work on f150s as well as mustangs. i figure it might need an adapter plug or somthin(no biggie) but based off all the stock photos when it comes time to shop, they make it difficult to tell. any input would be appreciated if any of you have swapped in an msd in the past thanx- mark
Old 10-03-2011, 10:06 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
why do you need an MSD unit? Honestly the stock distributors are plenty for our rigs.
if you must go this route you need to determine if you have a remote mounted tfi or if the tfi module is mounted on the side of the dizzy. if you call summit i am sure they will make sure you get the correct model for your rig.
I also wouldnt bother with the 6AL boxes. the stock ford ignition is plenty once again.
Old 10-03-2011, 10:22 AM
TheWhiteBeast's Avatar
TheWhiteBeast
TheWhiteBeast is offline
92 is remote. If you want a super good spark cannot go wrong with a 6AL. Depends on what your goals are. If you want the MSD dizzy, just buyt the ready to run pro billet.
Old 10-03-2011, 12:02 PM
Mark57Lee's Avatar
Mark57Lee
basically i'm looking to upgrade as the parts go. i've got some headers that i'm looking to install once i locate some gt40 heads but for now the ignition is whats getting beefed. i'm lookin for a ready to run pro billet distributor right now actually. does anyone have any advice or good feedback on these? do they coincide well with other msd stuff?
Old 10-03-2011, 12:10 PM
TheWhiteBeast
The ready to run is perfect for a truck. Go to a JY you can find 5.0 Explorers all day with heads/intakes everything.
Old 10-03-2011, 12:18 PM
lew52's Avatar
lew52
lew52 is offline
With the 6al and the other msd stuff is mosty just plug in , they all come with a wiring harness , tach just plugs into the box , also has the soft touch rev limiter has plug in pills to set it where you want....
Old 10-10-2011, 08:29 AM
Mark57Lee's Avatar
Mark57Lee
for the ready to run dizzy does the vaccum advance have to be used?
Old 10-10-2011, 08:39 AM
TheWhiteBeast
There is no vacuum advance it still uses the SPOUT if you get the correct model.
Old 10-10-2011, 02:20 PM
Mark57Lee's Avatar
Mark57Lee
alrighty so i ordered the distributor and it oughta be here in a few days. any heads up advice before i go tearin into this thing?
Old 10-10-2011, 02:31 PM
lew52's Avatar
lew52
lew52 is offline
Mark the distributor at the base , and where the rotor is pointing before you pull it out , so you can put the new dist in at the right spot , the base timing will need to be reset after , is your 92 a roller , some 92-93 had the small roller cam , if it is you will need a steel dist gear , msd may make a gear that works with both ??....
Old 10-10-2011, 02:42 PM
TheWhiteBeast
Should be billet steel
Old 10-13-2011, 08:27 AM
Mark57Lee's Avatar
Mark57Lee
alright guys, i got my distributor in the mail yesterday.to my dissapointment it had the tfi module on the side like for a mustang. now i'm wondering if i have to send this back or get an adapter harness. i been lookin on the web for such a harness and i'm not finding much. you fellas know of such a harness or should i just send it back for a different one? its got a steel gear on the new dizzy too, so i gotta find out if my 92 is a roller or not. any ideas on figurin out if its a roller?
Old 10-13-2011, 09:00 AM
TheWhiteBeast
It's all the same plug just the wires might not be long enough. When you order stuff like that you should really talk with a phone rep to make sure you are getting the right part. Anywho, the TFI module just unscrews from the distributor, so take it off, and put it on the heat sink.
Old 10-13-2011, 01:12 PM
Mark57Lee's Avatar
Mark57Lee
damnit am i glad you said that lol i been stewin on how i jumped the gun on orderin that dizzy and been checkin out some forums about the tfi relocation. it seems easy enough for a person that knows how to use a screw driver and a soldering gun. any input on what it takes for the relocation?
Old 10-13-2011, 01:22 PM
lew52's Avatar
lew52
lew52 is offline
You need to find out if your motor is a roller or not , if its not , your going to need to change the gear from steel to cast , the only way i know is to pull a valve cover and look though the push rod hole with a good flash light and see if you see the dog bones on the lifter , the 92-93 were hit or miss with the roller cams.....Lew
Quick Reply: 1992 f150 msd distributor swap NEED SOME HELP!!!
