How To Install LoCoFoMoCo Racing's Hydro Boost Conversion Kit
How too install LoCoFoMoCo Racing's hydro boost kit.
first remove old master cylenderand the 2 bolts above and the 1 below and clean off any debris in the aria
supplyed kit
remove 1 bolt from the stock backing plate.
use a pair of snap ring plyers to remove snap ring from in front of the nut to be removed.
use supplyed wrench to remove nut.
use die grinder to open up hole in firewall 1/16th of a inch use removed nut for a guide of how far to grind. when the nut slips through easly you are done.
install supplyed plate to the back of the hydro boost. do not tighten fully.clock to desired location and remove and snug down good. reinstall safty snap ring.
if you are clocking to a 90 degree offset you may need to cut down the master cyl bolts so your master cyl will fit. brake pedal and master cyl rods may need to be lenghthened or shortened depending on application.
Here are the outhe 3 mounting options to make a total of 4 options. custom degree offses available upon request for those tight fit situations.
call or e-mail for any install questions. Longhornliam@hotmail.com 206-769-6376
http://northwestclassicbroncos.com/s...l-think/page35
supplyed kit
heres my new hydro boost bracket and 90 degree turn bracket combo. you can run it in 4 different possisions for any clearance issue you may encounter i also include a specal wrench for the squair nut on the back of it. all 3 peices are $65+tax and $5 shipping.master cyl rod and brake pedal rod may need to be lenghtened or shortened depending on application. heres some pics.
alpha/omega
Offroad & 4x4
295
05-15-2014 09:36 PM
rideracelivemx7
35
06-04-2010 10:34 AM
frdf250
17
05-16-2010 12:39 PM
aerostar, boost, conversion, duty, ford, hydro, hydroboost, installing, kit, locofomoco, michigan, racings, super, truck, v10
