Home made rollback bed
Old 10-03-2011, 01:45 AM
markusselanne's Avatar
markusselanne
markusselanne is offline
I am building rollback bed to my F-450. Bed will roll 3m with bearings, and capasity will be 6000-7000lbs. How strong hydraulic cylinder do i need to pull bed up with load? I found a cheap cylinder for sale, it has 60mm piston and 50mm rod. I´m affraid thats too weak? It has only 8,7 cm2 in pulling side and power is about 2800lbs?
How big cylinders they use in jerr-dan and other small beds?
Old 10-03-2011, 08:22 AM
Edgethis's Avatar
Edgethis
Edgethis is offline
I drove a 95 F-Superduty roll back with an aluminum bed. It had twin cylinders tho to lift up and down as well as twin cylinders to slide front and back. There are alot of factors here beside simply the cylinder sizes. Make sure you factor in the frame length/strength as well as the weight of the actual roll back i.e. steel/aluminum and the advantages of each.
Old 10-03-2011, 09:24 AM
nstueve's Avatar
nstueve
nstueve is offline
I think you also need to factor in the size and gpm hydro pump you use... But that is more a function of the number and size of your cylinders.
79 F-150 Stone
34
10-20-2020 06:51 AM
Wagion
1999 to 2016 Super Duty
34
01-27-2011 06:43 PM
browntown3
09-16-2009 11:14 AM
texan2004
19
03-15-2007 09:50 AM
dtony
06-21-2005 12:39 PM
Quick Reply: Home made rollback bed
