almost stranded in BFE AGAIN!!!!!!
#31
ok, finally got back up under the truck today, THIS IS RIDICULOUS!!!!!! someone mentioned a metal cap, what if a rock hits the sensor port instead the effect is the same thing that happened to me. looking at the setup if they moved it higher up in the bracket that holds the assembly it would have helped protect it ALOT. not to mention the unit is plastic a rock could hit the unit itself and cause the same problem. looking again if you have big tires on your truck and a rock got stuck in the lugs it could go RIGHT for the unit. I am not sure quite how to protect the unit better short of something elaborate. I think they should have place it right in front of the fuel tank, that would have given it protection from the back, once I get the truck up and running and out of the street in front of my house I will get it into the garage and check it further. BTW this unit has been dripping fuel since 1:30 am sunday morning and I still spilled diesel all over myself and the street, just like epics video. I am starting to think its unavoidable. the part is costing me like $4 bucks, but they want like $74 bucks for the filter set, is this a good deal?? thats even with me getting wholesale discount on the parts
these are the fixes we did in the middle of the night.
looking closely the unit hangs down to the same level as the transfer case, the t case is metal and they make skid plates for that, wouldn't one would think a plastic part hanging down in the same area might be more deserving of a skid plate?? ford, you sucked on this one.
#34
Is the $4 part just the yellow valve?
The FD-4615 fuel filter kit costs about $57 online with shipping but I bet $75 is close to what most dealers charge.
I’m contemplating buying a spare lower DFCM bowl with valve if it's not outrageously expensive.
The chances of this happening are slim but being stranded over a piece of plastic isn't worth it.
Anyone know the part numbers to this unit?
#36
That there is a true Redneck fix! I've done some pretty creative fixes over the years myself.
Glad you were able to drive it home.
I don't think I'd approach Ford about a warranty on this though.
I'm pretty sure that this "fix" is not sealed from outside CONTANIMATION.
I think a mudflap type protector mounted just forward of the filter would give it a lot of protection and still leave it easy to service.
Rick, Glad to see you back. Still pulling for you.
#37
#38
putting a flap of rubber or cut mud flap is a great idea!!!! I might fashion my fix from that, or I was thinking of using an 8" ish 1/8 thick steel pipe and weld it to the bottom of the bracket that holds the unit. maybe make some cut outs or something to I can still get to it.
#39
Well someone asked about a machine shop; it so happens I'm an engineer and engineering department manager. We build custom food processing equipment for about 90% of the companies in the USA, it just so happens I have a full machine shop right outside my office door.
I'm going to go out tomorrow and look at my truck and come up with ideas. The bad thing is I'm laying at home, 2 weeks into a 4 week recovery from another back surgery. So anything I come up with and get made will be a month away probably. I'm going to look anyway and see if I can come up with something I can email to the office and have them work on something, that might be a stretch right now though.
#40
One option is to move the unit to a better location. 3 inches up would put it between the frame rails. This might be a bit redneck, but I unbolted it and shimed the bottom bolts with 3 washers each to twist it up. Then very carefuly used a bottle Jack and bent the brackets upward. I probably got an inch and a half more of clearance. (let's not get onto the water in fuel debate on this thread)
#41
#42
#43
Sorry about your back problems. Hope you get better.
ken
#44
#45
Did a simple mod last evening. Took a piece of alum. that I had and bent it at the angle of the skid plate of the tranny. Screwed it onto the tranny skid plat and back to the fuel tank skid plate. No rock is going to get thrown into it now. Be carefull and don't use to long of screws into the fuel tank skid plate.
