Motor Mount Location 5.0 Into 51 F1 - Ford Truck Enthusiasts Forums
Old 10-02-2011, 09:45 PM
animull animull is offline
animull is starting off with a positive reputation.
Question Motor Mount Location 5.0 Into 51 F1
I have been reading all the different threads, forums, talk sessions, etc... concerning the installation of 5.0 into a 51 Ford truck with an aftermarket Mustang II IFS installed on it. My question is: how did/do you determine where to locate, weld in, the engine mounts? The only answer I received back was, “not to high as the transmission rubs the cab and not to low as the engine cannot be seen when the hood is up!” I am kind of looking for some type of measurement as well as someone who has done it. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Help if you have the answer or can direct me to it.<o></o>
Thanks<o></o>
Background Info.<o></o>
1951 F1 (Completely striped down to bare metal)<o></o>
5.0 (302) (Out a 1989 Saleen Mustang)<o></o>
“WC” Borg-Warner T5 Transmission (Out a 1989 Saleen Mustang)<o></o>
9” Rear end (Out of a 1968 F100)<o></o>
Complete Mustang II IFS with Heidt Cross member (All installed on the 51 frame)<o></o>
Old 10-02-2011, 09:55 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Hey there! welcome to the forum! sounds like a pretty cool build.
There are many here that should be able to help you, so hang in there and someone will be right with you. Geez that sounds like I am in a Doctor's office!
Speaking of Doc....there is a member here, his username is "Doc" he just recently did something similar, might be of some help. I think he is out chasing a STEER right now(cow).
Old 10-05-2011, 03:58 PM
SVT-F100's Avatar
SVT-F100 SVT-F100 is offline
SVT-F100 is gaining momentum as a positive member of FTE.
Animull,
Hello there, and welcome to FTE, great place for help. I as well am doing something similar along with many others but on 53-56 trucks.
I have completed my No Limit IFS installation and my No Limit 4 link fatbar with a 97 expolder rear end 8.8". The motor is a 5.0 HO out of a 93 T-Bird I will be using mated to a AOD trans.
I have not mounted yet as I have been collecting all my parts (headers, poly mounts, steering column and accesories along with a rear sump oil pan needed for IFS, motor mount bracket metal etc). I have most parts now but still not quite there yet.
For all the research I have done no one has given me numbers and direct areas how to do it. Kind of what works best for your build.
This is my plan off the top of my head with high level idea:
-Assure truck is level is level front to back side to side
-have steering column in place with universal and extensions connected to the rack
-mate the trans and motor and assure motor mounts are on
-support rear of motor by placing transmission onto trans bracket with ability to move back and forth before I drill the trans x member holes.
-float motor about 1 inch to passenger side from center for more space on steering junk
-Attach headers
-adjust height of motor with cherry picker till I hit my desired pinion angle (3 down)
-once headers and everything is clear I will grab my metal slide the through bolt in on each side and mark holes to drill for trans xmember
-then I would tack in brackets (people here have made brackets to side of xmember or bottom)
-Remove the through bolts on the engine mounts and weld in for good
Hope this was of some help to you, and if not it was to me. First time i wrote my thoughts down
Old 10-05-2011, 07:46 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
I'm not sure it's useful to you but here is a picture of the 351W engine mounts on our 1950 F1 with a Mustang II IFRS. Note our engine also has a 3 degree pinion & is approx. 1 inch off center toward the passenger side. (I had expert help in setting the engine up).
Ben in Austin
Old 10-05-2011, 08:24 PM
Thumbs up Thanks To All
Thanks for the welcome. Thanks to all for your help.
The pictures are great and shows the detail I am looking for. My engine and tranny have been hanging on my cherry picker for three months now. With all this first class info, I am ready to start playing with it again. If you here of addition info, let me know. I have a feeling I am not the only one in the bucket.
Thanks again to all and I will let you all know how it works out.
Old 10-05-2011, 08:58 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
some weird computer glitch happened here.
Old 10-05-2011, 09:00 PM
52 Merc's Avatar
First, let me say welcome to the forum! Your project sounds pretty sweet.
That said, the answer to your question is probably not what you want to hear. There is no magic answer or one-size-fits-all measurement. Everyone's install is unique, and as such, you'll have to determine your own best placement with regards to floor and firewall clearance, radiator clearance, header clearance, steering linkage, crankshaft/pinion angle, oil pan and crossmember clearance, etc., etc., you get the idea. You really need to have all these other questions answered first, then build your engine mounts last and placed in a position that allows all the other items mentioned to work together.
Good luck with your project, and remember we are always here to listen and help.
Old 10-05-2011, 09:59 PM
ben73058's Avatar
Welcome aboard - just one last thought - the steering & headers are tight on the driver's side but once you get that figured out triple check the front clearance fan/shroud to radiator. We had to go with a very thin electronic fan up front to make it work - very close.up there. Good luck it sounds like a fun build!
Ben in Austin
Old 10-05-2011, 10:09 PM
Ben, is the cab in its proper place in that pic? My drivers side head is about a 1/2" from the firewall. I have a different setup completely, but its nice to see comparison 351w to 351w.
My steering situation is driving me crazy! I am not experienced in this steering redesign, whatsoever! In fact, I feel stupid sometimes!
Old 10-05-2011, 10:55 PM
ben73058's Avatar
Jeff,
That's a good question - We had the cab on & off of there so many times. I can say for certainty in the pic below it's all buttoned down in its proper locations. The angle isn't exactly the same but that is a pic I know was done after all adjusting..
Ben in Austin
AOD experts please help...rebuilt tranny Flintknapper Clutch, Transmission, Differential, Axle & Transfer Case 17 02-18-2015 09:00 PM
4.0 V6 to 4.6 V8 Eagle Spirit Engine Swaps 1 05-20-2014 02:04 PM
No Power/High Boost Problem. P0299 & P0478 Lowe 6.0L Power Stroke Diesel 20 07-12-2012 02:53 PM
Long to Start Rough when running 2003 Help Jnas860 6.0L Power Stroke Diesel 20 07-02-2012 03:19 PM
TOPPIN' IT ALL OFF 2010 bigc..ec Texas Chapter 2 05-22-2010 06:56 PM
Tags
1951, 50, 51, engine, f1, f100, fit, ford, location, motor, mount, mounts, sbf, swapping, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
