Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
Sign in using an external account
Register Forgot Password?
Appearance & Dress-Up SPONSORED BY:
  #1 (permalink)
Old 10-02-2011, 07:50 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
Garage is empty, add now
2006powerstroke90 has a good reputation on FTE.2006powerstroke90 has a good reputation on FTE.
Best wax?
I am looking for the best wax to use to get rid of them fine "car wash" scratches in the paint...
My truck is black and it stands out so well, I am not trying to make them dissapear for good, just to try and hide them some...
Whats the best wax I should use and what would the process be?
Thanks
__________________
Tyler, I now drive a Duramax.
2010 HD Sportster 48
Do it once do it right!
  #2 (permalink)
Old 10-02-2011, 10:46 PM
mblayton's Avatar
mblayton mblayton is offline
mblayton is starting off with a positive reputation.
I have found you need to Clay bar it first then I use either Carnuba (Malms) or NXT and you should dry it with "The Absorber"
My fine scratches have all but dissappeared.
__________________
69 F100 SWB, 66 Fairlane GTA, , 2005 Lincoln Navigator Ultimate
Ford Oakville Assembly plant employee 29 years and counting
  #3 (permalink)
Old 10-03-2011, 04:25 PM
Beechkid Beechkid is offline
Beechkid has a good reputation on FTE.Beechkid has a good reputation on FTE.Beechkid has a good reputation on FTE.
Thanks
1st item......Ford/GM/Chrysler/MB/Porsche all have service directives that specifically refer to paint correction/contamination procedures and clay bar is not a referred procedure and specifically identified as a method which only removes the surface level paint contaminants and as such, the "root' of the contaminant remains continues to destroy the paint from underneath the surface layer of the paint.
Just remember, Mequire's clay bar is rated at 3500 grit. There much better clay bar products out there rated at much finer grits- so if you are comfortable and believe your paint needs to be wet-sanded, and that is the only and safest way to correct the flaw/issue, then do so but remember, for 90% for all paint contamination issues there are products designed to relieve/remove/neutralize the contaminants without reducing the mil thickness of the clear coat
These procedures date back to 1990 and are still published in current oem paint maintenance publications/service manuals- PM me and I will send you a copy.
Now for the correction item...
I have found that 100% cloth diapers (24" x 24") doubled up are the best for washing/drying....not only in terms of price/longevity but the paint feels like it's been polished each time. FYI- the diapers must be flat fold (meaning no seams) and washed 3 times (typically) to ensure softness and absorbsion.
I have found that flannel (100% cotton) outperforms the microfiber wax removal towels consistently- cheaper, better, last longer, gives a much better shine/result
General paint maintenance
General paint cleaning (required if you need to complete paint correction) - use a 50/50 mix of denatured alcohol & water (denatured is available at any hardware store & is oil free). It will remove any wax/polish and most all environmental contamination & ensure you are starting with a very clean surface.
Swirl mark removal (your issue), 3M Imperial Hand Glaze (there is a specific one for dark colors & one for lighter colors). Not only does it fill/remove swirl marks & light scratches it feeds oils back into the paint giving a very, very deep look. Now with that said, I used another product for the 1st time on gloss black paint (BC/CC oem) - Pro P21 swirl eliminator & polish (absolutely excellent)- mirro finish & eliminated 95% of all marks on the 1st try.
The absolute best ($ for $) IMHO is "Satin Cream" (for dark colors), it is made by BAF & distributed through Pro Car Care products. It is very easy to work with either by hand, orbital or buffer. It has the same acrylic hardener as the high dollar paint sealants but it has 30% German imported carnuba....no, your arm will not fall off putting it on or taking it off & it has a very mild polish in it as well. Even parking the vehicle outside, the MFG gives a 6 months warranty before another application is required. I use this personally on my toys & daily drivers (which include a 1997 black Cougar sport) and all I can tell you are not even bugs like to stick to the paint- most of the time when water is applied they just float off- bird poop is just as easy. No smeary look either- very clean clear deep look. On my toys, I give them a fresh coat about every 2 years (literally, even for a show), my daily drivers (I have one that sits outside), I apply to the entire vehicle every 6 months, and do the hood, roof and trunk every 3 months (probably overkill, but I know it is well protected from the elements including industrial fallout)
An excellent alternate product is 3M Perfect It Show Car Liquid Wax- a silicone wax/polish but excellent results as well, just maybe about 90% of the quality of the satin cream.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #4 (permalink)
Old 10-11-2011, 02:41 PM
Merlinii's Avatar
Merlinii Merlinii is offline
2003 Ford F-150
Merlinii is starting off with a positive reputation.
I would suggest Wet Glaze 2.0 to hide fine swirls and scratches and enhance gloss
Follow that with Zaino Z-2 for protection and a long lasting, wet looking shine.
  #5 (permalink)
Old 10-11-2011, 05:09 PM
Here are my pics too....fyi the haze you see on the nose above the bumber and on the edge of the Mark LT hood is ClearBra
__________________
  #6 (permalink)
Old 10-12-2011, 01:17 AM
btm991 btm991 is offline
btm991 is starting off with a positive reputation.
Im know it's not the best but I use turtle wax black box. It comes with a cleaner wax and also a polishing wax and it seems to work very good. But i do reapply it every 3 washes which is about every 3 weeks.
  #7 (permalink)
Old 10-12-2011, 06:10 AM
Merlinii's Avatar
2003 Ford F-150
Quote:
I tried the stuff and I thought it was pretty nasty and did a poor job but I did like the black spray detailer.
  #8 (permalink)
Old 10-12-2011, 09:23 AM
Did the zaino do that much better?? And where can you get the zaino from?
  #9 (permalink)
Old 10-12-2011, 11:38 AM
Merlinii's Avatar
2003 Ford F-150
There are lots of Zaino Products I like:
Here are a few to get you started.
Most folks get 6-8 months from Z-2
Z-2 Sealant
ZFX Accelerator
Z-6 Quick Detailer
The Zaino Store
  #10 (permalink)
Old 02-02-2012, 04:32 PM
Briarcreekrat's Avatar
Briarcreekrat Briarcreekrat is offline
Briarcreekrat is starting off with a positive reputation.
Zaino is great product.
  #11 (permalink)
Old 02-03-2012, 04:59 AM
Merlinii's Avatar
2003 Ford F-150
Glazes not waxes or sealants are used to "fill" swirls and add gloss.
A LSP, as a rule, does not reduce the appearance of swirl marks.
Unless they are buffed or filled you will have very shiny swirls!
Poorboys Black Hole and Wet Glaze 2.0 are good to fill & add gloss.
Another real good combo (that I like) is:
BLACKFIRE Gloss Enhancing Polish
"It visually reduces swirl marks while creating a deep gloss."
use it before applying
BLACKFIRE Wet Diamond All Finish Paint Protection
These two products are made to work together.
"Grant me the power tools to correct what I can, the fillers to correct what I can't, and the wisdom to know the difference."
  #12 (permalink)
Old 02-03-2012, 04:30 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
1973 Ford F-100
My Garage
HIO Silver has a very good reputation on FTE.HIO Silver has a very good reputation on FTE.HIO Silver has a very good reputation on FTE.
I prefer machine-applied Meguiar's glaze and hand-applied Mother's pure carnauba.
__________________
73 F100 SB, 4x4, 390FE, NP435, NP203,+4 on 35s, 70 F100 LB, 2wd, 360 FE, NP435, 70K original miles, 01 F-150 SuperCrew Lariat 4x4, 5.4L, 01 PT Cruiser Limited (DD), 71 Pontiac Lemans Sport Convertible, 68 Mustang 200-1v, 65 Mustang 289-4v
Tags
20, alcohol, bestwaxforfordtrucks, black, car, cleaning, denatured, ford, glaze, good, harley, mix, nite, tge, truck, trucks, water, wax, wet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
