Why is my truck so slow? - Ford Truck Enthusiasts Forums
Old 10-02-2011, 08:47 PM
mr.fordneck's Avatar
mr.fordneck mr.fordneck is offline
mr.fordneck is starting off with a positive reputation.
1990 F150 5.0 zf5spd 4x4. When I have my foot to the floor, I can get passed by a school bus. Here's all the work I've had done by a shop (so I know it isnt the problem)
-New transmission seals and shift forks
-Head gasket
-valve job
-machine heads
-cleaning of all disassembled engine parts
-new jasper rear end
-sway bar, ball joints, tires
-all fluids correct levels
So, I think it might be an incorrect gearing between the front and rear axles. The front end was "rebuilt" before I bought the truck. I think it may be a different gear ratio than the jasper rear. Any ideas?
Old 10-02-2011, 09:12 PM
Bankrupter Bankrupter is offline
Bankrupter is gaining momentum as a positive member of FTE.
-Head gasket
-valve job
-machine heads
It would not matter unless your in four wheel drive. At that point you would know it real quick ....
Old 10-02-2011, 09:18 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Just a thought,, how are the catalytic converters? Stopped up maybe???
Old 10-02-2011, 09:19 PM
I mean when its in 4x4, it jumps and bogs down. It will not just drive amywhere near the way it does in 4x2
Old 10-02-2011, 09:21 PM
never checked em. Ill give that a shot
Old 10-02-2011, 09:26 PM
Jump, turn into scrap steel ( fork in a blender comes to mind) all things that would happen, yes. But in 2wd it would have zero effect on the drive line. Did you match the jasper to the door jam info?
Old 10-02-2011, 09:28 PM
If things aren't too rusty just loosen the studs at the manifolds to produce a pretty good leak, or take the pipes completely off the manifolds IF you can get the nuts off the studs with out too much trouble.. Don't forget to use plenty of PB blaster/ or your favorite penetrating oil. if things are really rusty start spraying a day or two in advance. Then drive it and see if there is any change..
Old 10-05-2011, 10:09 AM
junk_jivin38 junk_jivin38 is offline
junk_jivin38 is starting off with a positive reputation.
My son and i swapped the Mazda 5-spd in his 92, for a ZF trans...noticed the gearing difference right away...i was told the ZF is more of a heavy truck trans,thus geared lower and slower...made to haul a load...not haul a**...
That said, if it's only noticeable in 4x4, your diffs don't match, as others have said.
Old 10-05-2011, 01:50 PM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
There are 2 different ZF's. A close ratio for gassers and a wide ratio for diesels. If you have a wide ratio hooked to a 5.0, I am so sorry.
Old 10-05-2011, 01:56 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
Quote:
and how would he use a wide ratio behind a 5.0? the bolt pattern wouldnt work at all.
you need to do a few things here. first figure out what gears you have out back and in front. I wouldnt use 4wd until you confirm they are close.
What size tires are you running? also you shouldnt be using first gear unless your wanting to CRAWL. first is a granny low gear similar to the old NP435 4speed trannies. and like mentioned this is a HD tranny geared lower then the m5od you previously had.
Old 10-05-2011, 02:32 PM
Could someone have changed the bell housing?
Old 10-05-2011, 03:31 PM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Be sure to check the initial timing of the distributor. Should be around 10 degrees BTDC.
Old 10-05-2011, 03:49 PM
mpc07005's Avatar
mpc07005 mpc07005 is offline
mpc07005 is starting off with a positive reputation.
No, the zf bell housing is integrated, and the wide ratio zf would not fit behind a small block. And make sure you remove the SPOUT jumper if you have a tfi control module (cant remember if 90's were)
Old 10-05-2011, 05:58 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
You guys all missed the obvious. It is a 5.0 and that is why it is slow
Old 10-05-2011, 06:02 PM
Quote:
ROTFLMAO
'91 F150 SCSB 4x4 Build & Updates thethrill 1987 - 1996 F150 & Larger F-Series Trucks 16 07-07-2016 10:34 AM
Should I trade or give Jasper one more chance? nationm 2004 - 2008 F150 3 05-22-2013 03:47 PM
Removing U joints from driveshaft? mr.fordneck 1987 - 1996 F150 & Larger F-Series Trucks 2 11-07-2011 02:58 PM
Jasper Transmission vs Ford Rebuilt 4R75E FordTruckLover1999 2004 - 2008 F150 5 03-09-2010 06:19 PM
Jasper 4R100 Trans robinsonpowerstroke 1999 to 2016 Super Duty 9 09-22-2007 12:50 PM
Tags
1994, 1995, 50, 88, e350, end, f150, ford, gasket, head, inline, power, rear, repair, slow, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
