brake booster or master cylinder
Years ago i bought the break booster and master cylinder from james duff. the bronco set up for 6 years with a blown motor. Im not sure if the booster is going bad or the cylinder. i have new rubber lines and have bleed the thing to death but I dont seam to have much peedle. What donor vehicle would the power booster and master cylinder come off of? also, any ideas on how to fix it? I have also installed new self adjusters and all new brake cylinders. Maybe new shoes will fix it?
Some have used the astro van's hydro boost on the EB...
Make sure you have your brake shoes adjusted up properly to start with. Tighten them up till you hear and feel the shoes contacting the drum. You also have to bench bleed the master cylinder first before the wheel cylinders. As far as parts from another vehicle being compatable, NumberDummy would be the man. ( Or a NAPA dealer that still has books as a backup reference to his computer).
New fella here w/ alotta experience may help:
New guy here..heres my pics.
New guy here..heres my pics. - Ford Truck Enthusiasts Forums
In forum: 1966 - 1977 Early Broncos
Started by: LoCoFoMoCo Racing
Richard's (above) got the best advice
"...till you hear and feel the shoes contacting the drum..."
Spin em till they drag a lill (sound & see em "not go very fast").
eknight
12-28-2019 08:53 AM
superman64011
03-06-2005 05:56 PM
