Swap M5OD Mazda to ZF 5 speed in a f150 is it a direct bolt up - Ford Truck Enthusiasts Forums
Old 10-02-2011, 06:53 PM
Jason302 Jason302 is offline
Jason302 is starting off with a positive reputation.
i have a 302 4x4 f150 with the mazda m5od trans and i want to put the heavy zf 5 speed trans in the truck. will i have to change anything or is it as simple as just switching the transmissions. thanks
Old 10-02-2011, 08:30 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
You will need a tranny that comes from a 4x4 heavy duty F250, or F350 with the following engines - 300-6cyl, 302 or 351.
The truck the ZF5 comes out of, MUST be a 4x4 also. Converting a 2wd tranny to 4x4 is not worth the effort. The entire tranny has to be tooken apart.... and the ZF5 is no walk in the park!
The ZF5 is shorter than your M5R2 Mazda tranny, so you will need a new driveshaft.
For these kind of things, it's sometimes cheaper and easier, finding a whole donor truck.
But yes, as long as the 4x4 ZF5 comes off a 300-6cyl, 302 or 351, shes a direct bolt in deal!
Old 10-02-2011, 10:55 PM
nighthawk285's Avatar
nighthawk285 nighthawk285 is offline
nighthawk285 has a very good reputation on FTE.nighthawk285 has a very good reputation on FTE.nighthawk285 has a very good reputation on FTE.
Yep, grab the parts and bolt her in! I converted my F150 from the AOD automatic to the ZF5 a couple years ago. There are a couple differences (like the difference in length, but driveshafts are easy to find at a salvage yard if you've got one nearby), and you might need a different hose for the clutch ( I don't remember off-hand). Hope this helps!
Old 10-03-2011, 12:39 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Is it REALLY worth the swap? For someone who doesn't haul much...
Seems a close ratio ZF would suit me.....I need a slave cylinder, shifter forks, etc.....About $350-400 as is.....
Sooooo
Would I be better off with a close ratio ZF? I have a 4x2 truck.....
Old 10-03-2011, 12:43 AM
I don't know about you, but my parts truck had a Mazda tranny, and I absolutely hated the really tall reverse gear! And the truck had 3.55's!
My ZF5 has 377k miles behind my 7.3 Diesel and i've never touched it...., Reverse loves grinding sometimes, but that's the only common problem with the ZF.
Old 10-03-2011, 12:52 AM
I don't mind the reverse gear...Its the d**** forward gears.....3rd is my stoutest pulling gear.....If 1,2,4,5 was more like 3rd....I'd leave it alone...
Old 10-03-2011, 03:15 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
Quote:
I have noticed the same in my 88, shoot, with the 3.55's and 32's it doesn't even get into 5th all that often. but thats why my bronco has an 8 speed
Old 10-03-2011, 03:58 AM
Quote:
If I could simply swap the actual gears out...I'd be happy.....
I mean hell...The danged thing already shifts like a stinkin dumptruck...Why not add the plunger handle in a bucket of gravel shifter also?
Old 10-03-2011, 06:49 AM
GIGGER's Avatar
GIGGER GIGGER is online now
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Good Moanday Morning Wes
Old 10-03-2011, 06:59 PM
'89F2urd's Avatar
'89F2urd '89F2urd is offline
'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.
the zf5 is a much more truck/tow-friendly tranny. the mazda trans is a pretty tall tranny, i always felt like it shoulda been in a car vs a truck. . .if you dont like your mazda gears, i think youd be quite happy with the zf5. keep in mind 1st gear is granny so you'd prob never take off in 1st unloaded with your 2wd.
to the OP: as long as you have the right zf5 to mate your 302 4x4, then its a direct swap for the mazda trans. i changed nothing when i did mine.
Old 10-04-2011, 04:05 AM
Quote:
like a thunderbird?
Old 10-06-2011, 03:01 AM
joethef150guy joethef150guy is offline
joethef150guy is starting off with a positive reputation.
You will need a tranny that comes from a 4x4 heavy duty F250, or F350 with the following engines - 300-6cyl, 302 or 351. The truck the ZF5 comes out of, MUST be a 4x4 also. Converting a 2wd tranny to 4x4 is not worth the effort. ... The ZF5 is shorter than your M5R2 Mazda tranny, so you will need a new driveshaft. ... But yes, as long as the 4x4 ZF5 comes off a 300-6cyl, 302 or 351, shes a direct bolt in deal!
in my case, i have a 2WD F150 with the M5OD bolted to a 4.2L V6... is there a ZF5 i could swap in as a "direct bolt up"?
my truck is a 2000 regular cab with the 6 1/2 foot bed.
Old 10-06-2011, 10:06 AM
I know nothing of the bolt paterns on the Ford modular engines, you'd have to ask in the 97-03 F-series forum.
Old 10-06-2011, 03:18 PM
im pretty darn sure that the pattern is different and if you wanted something strong it would have to be from behind either a 5.4 or v10. if they even got 5 speeds...
Old 10-06-2011, 07:59 PM
jwc9 jwc9 is offline
jwc9 is starting off with a positive reputation.
I am looking for a donor truck to change out my 96 4x4 5 spd to a zf 5 speed. I understand it must be a 4x4, 300,302 or 351 but what years would I need to narrow my search to? How do you identify the zf? Thanks!
T-18 to M5OD swap? blue money pit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 01-02-2011 06:08 PM
Putting a ZF 5 speed in a 1996 F-150 Torchin' an Truckin' 1987 - 1996 F150 & Larger F-Series Trucks 4 07-19-2010 10:42 AM
mazda 5spd to zf 5 spd MeBadDog2002 Clutch, Transmission, Differential, Axle & Transfer Case 7 04-29-2004 10:44 PM
do i have the mazda 5 speed or the ZF?? fordtrck302 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 04-03-2004 01:01 PM
Wanting to buy a used/rebuilt/new ZF-S542 to replace Mazda 5-speed. bubbaredneck Clutch, Transmission, Differential, Axle & Transfer Case 15 02-13-2002 08:57 PM
Tags
1987, 1989, 2000, 302 zf, change, cylinder, f150, ford, m5od, sale, slave, speed, swap, zf, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
