Swap M5OD Mazda to ZF 5 speed in a f150 is it a direct bolt up
#31
Having my mech. replace my M5OD with a ZF S5-42 in my '95 F-150 4x4 w/302.
Getting the ZF from a JY, but she isn't coming with the shifter. I've scoured the internet and called a few JYs with no luck, does anyone know where I could get a ZF S5-42 shift lever/boot?
If there anything else that you could think of that I need to get/order while I'm at it? He's putting a new clutch in it as well.
ZF Transmission Parts | Genuine ZF Replacement Parts | Transmission Repair | Direct Wholesale Part at ZFtransmissionpart.com
several others if you search it out.
#33
digging up a dinosaur, but here is the deal with ZF's
S = Designates a synchronized transmission
5 = number of forward gears
42 = Approximate maximum input torque capacity in tens of Ft-Lbs (42=420; 47=470)
Available in wide ratio and close ratio. Wide ratio were available in all f-series trucks over 8,500 GVW, all engines. Except the F-Super Duty Commercial Stripped Chassis with diesel engines. The close ratio version was available only with F-Series vehicles with a 7.3L diesel engine over 8,500 GVW.
--------------------------1st 2nd 3rd 4th 5th rev
Close Ratio
Diesel ------------------ 4.14 2.37 1.42 1.0 0.77 3.79
Wide Ratio
Gas/Diesel --------------- 5.72 2.94 1.61 1.0 0.76 5.24
Close Ratio
Wide Ratio
Charlie01
11-22-2004 01:03 AM
tjgraf
10-13-2003 06:07 AM
MustangGT221
12-29-2001 01:16 PM
ChadR93
11-29-2001 05:31 PM
