Rear end problems?
Rear end problems?
When under heavy load (goin up a hill) it almost like the rear end is slipping. Is that possible?? When I go into 4 wheel it seems to go away. Coud this be because of less pressure on the rear end??? I have also started hearing a whining soud. I think I have that is, my exhaust is super loud so kinda hard to listin for it goin down the road. It used to only do it in 4th and 5th but now does it in 3rd to under load. Any suggestions?? I havent put a magnet in through the fill hole yet but will soon.
1990 F-250 5L 302 4x4 dana 44's front and rear If i remember right
Thanks Josh
Thanks Josh
Received 5,131 Likes
on
on
Thanks for the replies!! Im 17 and still learning about cars and trucks. I didnt think about it being the clutch thats slipping. It is getting a lil harder to shift gears but I also think Im getting low on fluid. I have been trying to check but not even a 19in breaker bar can break the bolt loose. Thanks again!
Josh
Josh
on
on
on
Just got through checking it and it was half a quart low (no where near what I was expecting it to be). So we topped it off with mecron atf fluid. Started to go with gear oil but the book and a very good mechanic said other wise so went with that. Does any one know why the 5 speed takes ATF and the 4 speed would take gear oil????
Tex51
20
03-09-2019 04:42 PM
tow4show
11-16-2006 10:37 AM
