Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Missouri Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
  #1 (permalink)
Old 10-01-2011, 04:17 PM
Hammertime01's Avatar
Hammertime01 Hammertime01 is offline
1976 Ford F-150
Hammertime01 is starting off with a positive reputation.
Compression questions
I have a 1976 Ford F 150 with a 360 Fe,
my compressions are as follows
1: 111 psi
2: 95 psi
3: 111 psi
4: 105 psi
5: 111 psi
6: 105 psi
7: 80 psi
8: 109 psi
Is this ok or do I have problems
what is the compression supposed to be stock
  #2 (permalink)
Old 10-01-2011, 04:58 PM
j20owner's Avatar
j20owner j20owner is offline
1990 Ford F-150
j20owner is starting off with a positive reputation.
IMO all of those are very low. Should be close to 75psi on the first pump and over 125 after 4. Is the engine currently able to run? I'd say warm it up good and then check again. Also, make sure you hold open the throttle blades while cranking over and have a battery charger on it at the same time. That way you won't deplete the battery while doing the check.
You might also squirt a shot of oil into each cylinder immediately before testing to see if it helps the rings seal better.
  #3 (permalink)
Old 10-01-2011, 07:14 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
Garage is empty, add now
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
That engine should have about 130psi(ish in every cylinder. J20 (sorry I forgot your name) is right on how to check them. My thoughts are bad valve seats. If this is the case the oil trick won't matter much. If it's rings, the compression should go up a little.
After all, the engine is 37 years old. I'll be 39 in a couple months and I'm worn out too. It may be time for a rebuild.
__________________
Alan Fenstermaker
'79 F-150 300-6, 4 spd. 4x4
  #4 (permalink)
Old 10-01-2011, 07:42 PM
1976 Ford F-150
Thanks guys. Earthquake you make a lot of sense and that's hilarious
  #5 (permalink)
Old 10-01-2011, 09:08 PM
tcbofade's Avatar
tcbofade tcbofade is offline
1986 Ford F-150
tcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputation
I'm betting valve seats as well...good luck!
__________________
Join the Missouri Chapter!
If my Aunt had stones, she'd be my Uncle...
  #6 (permalink)
Old 10-01-2011, 09:19 PM
1976 Ford F-150
Ill be working on it soon ill let y'all know I appreciate the replys.
  #7 (permalink)
Old 10-01-2011, 09:20 PM
1976 Ford F-150
O and yes the engine does run and it even runs strong it just sounds like crap.
  #8 (permalink)
Old 10-01-2011, 11:56 PM
1976 Ford F-150
Tags
109, 150, 1976, 1980, 302, compression, ford, psi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
