1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
automatic shifter rebuild
Old 08-18-2012, 12:26 PM
widowson2's Avatar
widowson2
widowson2 is offline
man you guys are great just joined site and in 15 minutes I have diagnosed my problem learned how to do repair and where to get my parts! Thanks!
  #32
Old 08-18-2012, 08:30 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
COOL! Happy to hear that someone could make use of the pics and captions. Took a long dang time to write that stuff up.
  #33
Old 01-09-2013, 04:19 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
I need to do this (as I'm sure everyone here does). Damn I was hoping it would be easier. *sigh*
  #34
Old 01-09-2013, 04:30 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
EASIER? Dude, I provided all the pics and instructions! Sheez.
If you can change your oil, filter and fuel bowl filter you can do this. Believe me. Its no big deal.
Deep breath, positive attitude....it will be fun. I promise.
  #35
Old 01-11-2013, 10:58 PM
WP1's Avatar
WP1
WP1 is offline
First, thank you fte for all the useful info you've given over the years hope i can give back for once. I had extreme slop in the shifter on my f250 as described above. I replaced the shift tube assembly twice, used loctite on the two torx head bolts in the back, and still had slop in the shifter. The final time I took it apart the spring in the shift tube fell out and I noticed the spring was worn. Took apart my old man's 03 f250 (only 30000mi) still tight shifter. Spring was originally about an inch long, mine was less than 1/2. Replaced the spring and bingo brand new feel. Hope this helps. Once again thanks.
  #36
Old 09-07-2013, 09:21 AM
James Eddie Long Jr's Avatar
James Eddie Long Jr
James Eddie Long Jr is offline
Did as shown in post everything works except key switch does not read that key is removed and will not start.
  #37
Old 09-09-2013, 10:55 AM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Mr., you did not put it all back together correctly.
  #38
Old 10-07-2013, 06:25 PM
AndersonPlow's Avatar
AndersonPlow
AndersonPlow is offline
I just did this job for the second time. First was at 50k and now again at 70k. I assumed this was because I do a lot of plowing, but I know people with similar trucks that plow and have way more miles with no problems. I now know mine is way harder to shift than the others.
I disconnected the cable from the tranny to see if it was bound. The shifter is free and smooth. When I hook the cable back up it becomes very hard to shift. I was wondering if anyone has an idea of what would be binding at the tranny? If I don't fix it, I know I will be doing the shift tube over real soon.
Thanks for the help.
  #39
Old 10-07-2013, 07:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
The problem is the TRS (Transmission Range Sensor.). It is the sensor on the driver's side of the trans where the shift cable attaches.
  #40
Old 10-07-2013, 08:12 PM
AndersonPlow
I was hoping that would be the case. Thank you Mark.
  #41
Old 10-08-2013, 10:22 AM
Lex2002's Avatar
Lex2002
Lex2002 is offline
How do you fix it?
  #42
Old 10-08-2013, 10:27 AM
Mark Kovalsky
You get a new TRS and replace the bad one. A new TRS is about $40 at any auto parts store. They might call it an MLPS (Manual Lever Position Sensor ) or a NSS (Neutral Safety Switch.)
  #43
Old 10-08-2013, 11:39 AM
AndersonPlow
I am heading to the parts store after work to grab one. I will let you know how it works.
Thanks again.
  #44
Old 10-08-2013, 02:18 PM
AndersonPlow
That fixed it. Everything is smooth and free.
Thanks again
  #45
Old 10-08-2013, 02:25 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Thanks again
WOW that was fast! No pictures for us?
Quick Reply: automatic shifter rebuild
