automatic shifter rebuild - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 08-18-2012, 01:26 PM
widowson2 widowson2 is offline
widowson2 is starting off with a positive reputation.
man you guys are great just joined site and in 15 minutes I have diagnosed my problem learned how to do repair and where to get my parts! Thanks!
  #32
Old 08-18-2012, 09:30 PM
Lex2002 Lex2002 is offline
Lex2002 is gaining momentum as a positive member of FTE.
Quote:
COOL! Happy to hear that someone could make use of the pics and captions. Took a long dang time to write that stuff up.
  #33
Old 01-09-2013, 05:19 PM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Finally happy...
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
I need to do this (as I'm sure everyone here does). Damn I was hoping it would be easier. *sigh*
  #34
Old 01-09-2013, 05:30 PM
Quote:
EASIER? Dude, I provided all the pics and instructions! Sheez.
If you can change your oil, filter and fuel bowl filter you can do this. Believe me. Its no big deal.
Deep breath, positive attitude....it will be fun. I promise.
  #35
Old 01-11-2013, 11:58 PM
WP1 WP1 is offline
WP1 is starting off with a positive reputation.
First, thank you fte for all the useful info you've given over the years hope i can give back for once. I had extreme slop in the shifter on my f250 as described above. I replaced the shift tube assembly twice, used loctite on the two torx head bolts in the back, and still had slop in the shifter. The final time I took it apart the spring in the shift tube fell out and I noticed the spring was worn. Took apart my old man's 03 f250 (only 30000mi) still tight shifter. Spring was originally about an inch long, mine was less than 1/2. Replaced the spring and bingo brand new feel. Hope this helps. Once again thanks.
  #36
Old 09-07-2013, 10:21 AM
James Eddie Long Jr James Eddie Long Jr is offline
James Eddie Long Jr is starting off with a positive reputation.
Did as shown in post everything works except key switch does not read that key is removed and will not start.
  #37
Old 09-09-2013, 11:55 AM
Quote:
Mr., you did not put it all back together correctly.
  #38
Old 10-07-2013, 07:25 PM
AndersonPlow AndersonPlow is offline
AndersonPlow is starting off with a positive reputation.
I just did this job for the second time. First was at 50k and now again at 70k. I assumed this was because I do a lot of plowing, but I know people with similar trucks that plow and have way more miles with no problems. I now know mine is way harder to shift than the others.
I disconnected the cable from the tranny to see if it was bound. The shifter is free and smooth. When I hook the cable back up it becomes very hard to shift. I was wondering if anyone has an idea of what would be binding at the tranny? If I don't fix it, I know I will be doing the shift tube over real soon.
Thanks for the help.
  #39
Old 10-07-2013, 08:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The problem is the TRS (Transmission Range Sensor.). It is the sensor on the driver's side of the trans where the shift cable attaches.
  #40
Old 10-07-2013, 09:12 PM
Quote:
I was hoping that would be the case. Thank you Mark.
  #41
Old 10-08-2013, 11:22 AM
How do you fix it?
  #42
Old 10-08-2013, 11:27 AM
You get a new TRS and replace the bad one. A new TRS is about $40 at any auto parts store. They might call it an MLPS (Manual Lever Position Sensor ) or a NSS (Neutral Safety Switch.)
  #43
Old 10-08-2013, 12:39 PM
I am heading to the parts store after work to grab one. I will let you know how it works.
Thanks again.
  #44
Old 10-08-2013, 03:18 PM
That fixed it. Everything is smooth and free.
Thanks again
  #45
Old 10-08-2013, 03:25 PM
Quote:
Thanks again
WOW that was fast! No pictures for us?
Driver Door 79 F-100 Custom scottness2 WTB - Ford Trucks & other vehicles 0 10-21-2015 09:11 AM
How to install a fuel pump? nse1355 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 11-08-2014 03:37 PM
WTB-NP203 shifter knob scott79 WTB - Parts & other 1 06-16-2014 03:54 PM
Power Steering Pump Bracket 79 F100 6 cyl scottness2 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-27-2014 07:10 PM
column shifter skotyg 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-12-2013 07:08 PM
Tags
1973, 450, 97, automatic, broke, column, diesel, ford, free, full, shifter, tranny, transmission, trucks, tube, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
