Another fuel problem
Old 10-01-2011, 05:26 AM
mississippiheat's Avatar
mississippiheat
mississippiheat is offline
Ok, I have done a search in the forums and have found some good info, but not what I need. I have a 93 F150, 5.0, auto, dual tanks. I was driving along and the truck quit running like it was out of fuel. Swapping tank selections didn't work and it was pulled home. After looking on the site the info pointed me to the electrical system. I found that I have power to the main yellow wire going into the fuel pressure relay but none coming out. So I jumped the connections and heard the pumps kick on. Great so I replaced the fuel pressure relay and still had the same problem. When I add power across the relay ever thing seems to work, but still won't fire up. While checking the relay box for loose wires I found that if I used a test light on the green/ yellow wire coming from the fuel relay, the light would light up and the pumps tried to work. While looking at the wiring diagram I see that the ground to the system is located after the fuel pumps. So one pump is louder than the other pump, when I force them to work. Could this whole problem be from a faulty fuel pump. By the way if I add fuel through the TB the truck fires right up.
Old 10-01-2011, 07:53 AM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
I wouldn't discount a possible electrical problem just yet, the PIP circuit and TFI are notorious. When they cool down, boom they work again...have you pulled any codes? you may want to take a fuel pressure reading as-well, 2 pumps failing is long odds though. In normal start sequence do you hear a pump kick on for a second or two? things to check out also are the selector switch, and the emergency switch
Old 10-01-2011, 07:54 AM
Nealcrenshaw's Avatar
Nealcrenshaw
Nealcrenshaw is offline
DI you replace the old relay with a new relay?
Old 10-01-2011, 09:05 PM
mississippiheat
Slip Ford Man - I have not pulled any codes and I don't hear the pumps cycling when I first try to start it. I have checked power to the selector switch and the emergency switch, I have power when I use a jumper wire.
Nealcrenshaw - I did replace the relay with a new one.
Old 10-01-2011, 09:11 PM
fordmudder92's Avatar
fordmudder92
fordmudder92 is offline
check to see if you have continuity in the inertia switch.
Old 10-01-2011, 09:45 PM
mississippiheat
fordmudder92 - I have continuity to the inertia switch when I use a jumper wire across the fuel pump relay.
Old 10-01-2011, 11:58 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,157 Likes on 915 Posts
Check the Red wire that feeds power to the coil of the Fuel Pump relay. Use this for reference:
Courtesy of FordFuelInjection.com
The ignition key turns on the PCM relay which in turn supplies power to the Fuel Pump relay coil. The PCM also supplies the return path for the Fuel Pump relay coil.
Old 10-05-2011, 07:08 PM
gatormccluskey's Avatar
gatormccluskey
gatormccluskey is offline
mississippi >> If I can help, contact me. I am in Biloxi all the time.
Old 10-05-2011, 11:47 PM
mississippiheat
Thanks Gator,
But work has me snowed under right now. You know after looking at the wiring and all I think the whole system grounds after the fuel pump and I think that if my if one of my pumps are bad it may not be getting to ground. When I use a test light to ground it tries to pump. Make any sense?
Old 12-13-2012, 05:26 PM
mississippiheat
Well I know it been a long time but i got it fixed, my issue was the ECM. I took to it to a shop and they found the right side of the ECM was burned up.
Old 12-13-2012, 05:53 PM
rla2005's Avatar
rla2005
rla2005 is offline
Glad to hear you found the cause and got it resolved.
Hover
05-16-2019 07:50 PM
Opossum
17
09-26-2012 06:42 PM
WildlandFirefighter
1978 - 1996 Big Bronco
08-20-2011 03:01 PM
gman41364
1983 - 2012 Ranger & B-Series
08-08-2007 11:46 AM
sweet82
05-09-2001 11:10 AM
Quick Reply: Another fuel problem
