F250 rear axle
09-30-2011, 11:43 PM
on
F250 rear axle
I have a 1981 F250 wth the Dana 60, 3.54 ratio, full floating rear axle that I need to replace. What years of vehicle are a direct bolt on interchangable axle that I can look for?
Thanks
09-30-2011, 11:47 PM
All F-series 1980-1997.
Note: axle must come from a pickup truck and not a cab/chassis as those have a narrower frame and axle will be shorter.
Dana axles from 80-85
85-97 are Ford Sterling axles.
Dana gears are 3.54/4.11
Ford gears are 3.55/4.10
10-01-2011, 12:21 AM
on
So an axle from a 1980 to 1985 pickup truck are what I need to look for.
10-01-2011, 02:47 PM
If you wanna keep it a Dana, yes. But a Sterling will still be a direct bolt. And the Sterling is superior to a Dana 60....
10-01-2011, 06:47 PM
on
I would replace it with a long pinion (90s) Sterling. It's a very tough axle and be less likely to be worn out. I buy them all the time out here for about $100 a piece.
10-01-2011, 06:58 PM
Long pinion would require a shorter driveshaft correct? Try not to leave out any of the dirty details that someone finds out later.
10-01-2011, 08:02 PM
on
Quote:
Originally Posted by
Franklin2
The length difference is about 1/2 inch. Should be more than enough plunge in the factory shaft to deal with that.
10-01-2011, 11:07 PM
on
Will a Sterling 3.55 work, or do I need to keep it a 3.54?
Thanks for the the help.
10-01-2011, 11:08 PM
Is your truck 4x4?
If 2wd, you won't notice a difference! Even with 4wd, won't bother anything.
10-01-2011, 11:57 PM
on
mrwake
24
03-02-2008 07:50 PM
79_250RangerLariat
01-05-2006 06:54 PM
rustyolred27
05-16-2003 07:00 PM
i looove fords
02-23-2003 02:20 AM
1986 ,
2011 ,
3006 ,
354 ,
86 ,
axel ,
axle ,
axles ,
end ,
f2005 ,
f250 ,
ford ,
ratings ,
rear ,
sterling
