Wiper problems??
Wiper problems??
Hello. I have an 86 F150 that I'm having some wiper issues with. Earlier this summer, my original 2 speed wiper switch finally died. I have an 87 sitting around for parts and it had the intermittent wiper switch in it. I swapped the intermittent switch and brainbox to my 86. It worked fine for most of the summer until a couple of weeks ago. It started not working on the low speed position and then wouldn't work in the intermittent position. It now only works on the high speed. I was guessing that maybe the switch was getting old and tired so I disassembled the switch to clean and look at the contacts. The contacts all looked pretty good to me. I cleaned and relubed the switch with some dielectric grease and put it back together. I installed it and it still only works on high. Sooo... what do you guys think??? Should I replace the switch?? Is it the brainbox??? If there is a chance of it being the brainbox, I will just switch back to a 2 speed switch as I have another good one on hand. But.... the intermittent sure is nice... What do you guys think? Is it the switch or brainbox???
Ben
Ben
There is a chance it's the governor (black box) and there's also a chance it's the motor, so disconnect the interval stuff and put your original switch in place and see what happens.
There are at least 11 pages of wiper system diagnosis in the Ford shop manual, I'm not gonna type all of that, should be able to look at it more closely over the weekend and post some more if needed.
The solder joints inside the governor tend to crack and you will be left with high speed only.
This can usually be repaired.
Seems to stem from the fact that every time you release the parking brake that the box is mounted to it receives a jolt.
I left the bracket off mine, wrapped it in foam rubber and ziptied it up behind the fuse panel.
Haven't had any trouble since then.
I remember 81-F-150-Explorer telling us this, I just looked it up and verified but I nevertheless can't imagine anybody in real life is gonna do it....
The Owner's Manual lists a procedure for releasing the parking brake, it has one depressing the pedal with their left foot while pulling the release handle, then lift your foot from the parking brake pedal, the implication being the pedal is gently released.
Well, I'm guessing that there is a good chance the solder joints have cracked. The pickup never sees pavement and for the last 3 months or so, our county road has been absolutely horrible. We have washboards that are a good three and even four inches deep in many places. They just shake the hell outa everything. I'm guessing all this beating has taken its toll. I'll maybe see if I can take the thing apart and solder it. If I get it fixed I'll do the wrap it in foam thing.
Thanks!
Ben
Ben, look for the seam where it's glued (hint it runs across the wire openings) and carefully pry the cas apart. Hopefully you will be able to see where it has come unsoldered. If in doubt just heat each connection carefully so you don't damage the board. Maybe someone else has some pictures, I have never had to repair any of mine. Once you finish, I would suggest you plug it back in and try it. The relay should close and stay closed in low, close briefly and open for intermittant.
http://www.flickr.com/photos/24183730@N03/6226849329/http://www.flickr.com/photos/24183730@N03/6226849329/ by http://www.flickr.com/people/24183730@N03/, on Flickr
http://www.flickr.com/photos/24183730@N03/6227370196/http://www.flickr.com/photos/24183730@N03/6227370196/ by http://www.flickr.com/people/24183730@N03/, on Flickr
On the rear of the governor is a metal strut secured by two 7/32" headed screws.
These also hold the box together.
http://www.flickr.com/photos/24183730@N03/6226865021/http://www.flickr.com/photos/24183730@N03/6226865021/ by http://www.flickr.com/people/24183730@N03/, on Flickr
Removing those screws allows the box to open and you will see the back side of the board with the broken joints.
Filp it over and you can see the heatsink where the damaged solder is attached.
http://www.flickr.com/photos/24183730@N03/6226877821/http://www.flickr.com/photos/24183730@N03/6226877821/ by http://www.flickr.com/people/24183730@N03/, on Flickr
Sycostang67
01-17-2010 04:53 AM
