Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-30-2011, 09:48 PM
irwnn irwnn is offline
Garage is empty, add now
irwnn is starting off with a positive reputation.
'65 Econoline Data Plate
I picked up a '65 E-160 Supervan back in July...
It's an extended regular van that went to the Los Angeles DSO from Loran, OH in March of 1965 with a 240 six "under the hood". It has a 90 inch wheel base, is (and was in March of '65) dark green with a standard green vinyl interior, but here's where it gets sticky: There are a few of the PLATE codes I'm having trouble with...
under BODY the plate reads: "3 89"
the 3 is standard green vinyl interior, right? But, what's the 89?
under TRANS the plate reads: "4G"
what's a 4G transmission?
under AXLE the plate reads: "13"
what's a 13 AXLE?
That's all I've got for now, but I'll be around.
Pete from Phoenix / Charlotte
http://flickr.com/gp/40848142@N06/X1WT84
  #2 (permalink)
Old 09-30-2011, 10:48 PM
Quote:
Originally Posted by irwnn View Post
...under AXLE the plate reads: "13"
what's a 13 AXLE?
The tag on the Diff reads:
WCR-L
3.00 5CC 765
p
http://flickr.com/gp/40848142@N06/08uh4r
  #3 (permalink)
Old 12-28-2011, 12:51 PM
EmilBarnabas EmilBarnabas is offline
EmilBarnabas is starting off with a positive reputation.
under BODY the plate reads: "3 89"[indent]the 3 is standard green vinyl interior, right? But, what's the 89?
The 89 means it's a van. 87 would be pickup.
  #4 (permalink)
Old 12-28-2011, 01:02 PM
under TRANS the plate reads: "4G" what's a 4G transmission?
under AXLE the plate reads: "13" what's a 13 AXLE?
4G on the trans has me puzzled.
in 1965, the G meant 3-speed trans.
In 1966, the G meant C-4 Automatic.
Which do you have?
There was no 13 axel code in 1965. Your Diff tag says 3.00 ratio which was not available that year.
In 1966, the 13 axel is a 4.56 ratio 9-inch rear.
Is the cover on the front or rear of your differential?
The dark green might be military, and sometimes they had special orders with special numbers.
What's your VIN? Maybe you have a 1965/1966 hybrid.
  #5 (permalink)
Old 01-01-2012, 08:19 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The tag on the Diff reads: WCR-L / 3.00 5CC 765
E100 SuperVan: WCR-L = (1965) Ford 9" Rear Axle w/a 8 3/4" Ring Gear / 3.00-1 / non Limited Slip / 2,700 lb. Rear Axle Capacity.
5CC = Assembled the 3rd week (C) of March (C), 1965 (5).
765 = Assembly Plant code.
I picked up a '65 E-160 Super Van last July.
No such thing as an E-160 SuperVan. 1961/67 Econolines are all E100's. Post the VIN & MODEL code stamped on Warranty Plate.
Warranty Plate AXLE code: 01 = 1965 WCR-L / WCR-L AXLE code used 1965 only.
TRANS code: G = C4 Cruise-O-Matic.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #6 (permalink)
Old 01-02-2012, 09:41 PM
I'm confused because my 1965 Ford Econoline Shop Manual says that in 1965 the G transmission was 3-speed, and the 01 axle was 3.50 ratio.
One problem might be that my shop manual was printed in September 1964, which is before the 1965 trucks were actually built.
  #7 (permalink)
Old 01-02-2012, 11:19 PM
Ford Parts Guru
2013 Ford Escape
1964/72 Ford Truck Parts Catalog / General Information Section-Page 75 / Main Transmission Codes:
F100/350 & Econoline: Ford used the Warranty Plate A/T code of G thru 1972 (actually thru 1978) for ALL A/T's. One had to know which A/T was available with what engine.
1964/72 Ford Truck Parts Catalog / Text Section 40.1, Page 5 / 1964/65 Warranty or Rating Plate Code Chart:
01 = Single Speed (1964) 3.50-1 (2.3M) Ford (WCC-A) Rear Axle Parts List # 89.
01 = Single Speed (1965) 3.00-1 (2.7M) Ford (WCR-L) Rear Axle Parts List #163.
Since historically, new vehicle introduction begins in September of the previous year, new vehicle production begins in August. 1965 model year began September 1964.
__________________
  #8 (permalink)
Old 01-05-2012, 12:03 AM
I guess this means that the parts catalog has more accurate information than the shop manual.
  #9 (permalink)
Old 01-05-2012, 02:55 AM
JimmerJoMoore's Avatar
JimmerJoMoore JimmerJoMoore is offline
JimmerJoMoore is starting off with a positive reputation.
how do i start my own new thread? and...
my 72 fordt 302 2bbl carb is over flowing gas onto the motor, someone said that the electric fuel pump is overpowering the carb and/or the float is sticking??? im gonna have to say huh?? please help
  #10 (permalink)
Old 02-14-2012, 11:49 AM
...No such thing as an E-160 SuperVan. 1961/67 Econolines are all E100's. Post the VIN & MODEL code stamped on Warranty Plate.
Hey folks! Sorry I took so long to get back here...
The VIN: E16JH...
The Model code: E160
Click the image to open in full size.
My indication that it was a 160 SuperVan came from the data plate info in the shop manual I purchased.
Thanks AGAIN NumberDummy.
p
  #11 (permalink)
Old 02-19-2012, 08:46 AM
Ford Parts Guru
2013 Ford Escape
The VIN: E16JH...
It's not an E160 because there was no such thing...as you can see.
E16 = E100 Super Van.
J = 240 IV 1-6.
H = Lorain OH Assembly Plant
Serial number blanked out.
90" Wheelbase.
L = Holly Green.
E160 = E100 Van (Extended), 3,600 lbs. GVWR
389: 3 = Medium Green Crush Vinyl & Medium Green Stitch Pattern Vinyl / 89 = Econoline Van.
4G: 4 = ? / G = C4 Cruise-O-Matic.
13 = Ford 9" Rear Axle / 4.57-1 / non Limited Slip.
3,600 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM.
71 = Los Angese (SoCal) Ford District Sales Office, where the original selling dealer ordered the Econoline from.
Oddities:
What the 4 refers to in the trans code, I haven't the slightest idea. IMO, it was stamped in error.
When you have a 240 I-6 in a 1965/74 Econoline, the only A/T available was the C4.
J VIN engine code was only used in 1965 for the 240 / A = 1966/74.
The E160 model code isn't listed until 1966, and there are different 4 variations of E160.
__________________
  #12 (permalink)
Old 02-22-2012, 10:25 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
That tag looks like it says 190 for the wheelbase. It looks like a 1 in front of the 90.
If so. That tag most likely has errors when stamped.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #13 (permalink)
Old 02-22-2012, 10:26 PM
66gpw's Avatar
I will correct myself. I blew the pic up and that is an 0 in front of the 90.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
Tags
1965, 65, 67, axle, data, e100, econoline, ford, inch, plate, rear, straight, super, van, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
