How to tell if shocks are bad?... - Ford Truck Enthusiasts Forums
Old 09-30-2011, 09:02 PM
Doug913 Doug913 is offline
Doug913 is starting off with a positive reputation.
Repeat ? from anther thread....please excuse....
With all the chat about bad rancho shocks, I removed the lower bolt on a rear shock. The shock was slow to extend, say 20seconds to finish extending. I was able to push the shock back up to were I could hold it in place with a thumb on one hand so I could re install the bolt with the other hand. Sooooo, what constitute a bad shock? The truck has ~7500miles on it.
Also those mounting bolts they use suck. On one side a 11/32 would fit. Then rotate it to line up with another set of flats on the hex and it wouldn't fit. I ended up using a 18mm & 15mm wrench. No big deal but yikes....
So bad shocks? (rancho of course)
Do the stock shocks suck that bad? Amelio 6.7L Power Stroke Diesel 45 02-23-2016 09:47 AM
V/B Spring Rancho Rs9000XL Question aaedin Excursion - King of SUVs 5 12-08-2014 01:12 PM
How To: Change Front & Rear Shocks warren561 1987 - 1996 F150 & Larger F-Series Trucks 1 09-12-2013 09:39 PM
Rancho 7000MT Shock Review A/Ox4 1999 to 2016 Super Duty 22 02-27-2012 11:50 AM
superduty & highboy shocks 71hightoy Offroad & 4x4 2 11-19-2009 12:09 PM
Tags
bad, checking, determin, ell, f250, ford, ho, how, image, pickup, ranger, shock, shocks, truck, trucks, wto
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
