Trim between front and back door on SuperCrew - Ford Truck Enthusiasts Forums
Old 09-30-2011, 08:43 PM
cubangt cubangt is offline
cubangt is starting off with a positive reputation.
I picked up my truck on Sept 5, after a few days of driving it and looking over the truck i noticed that the black plastic trim in the middle where the front and back doors meet were not aligned correctly. On the rear door the trim was lower by little less than 1/8" even though its not much, when you look at the side of the truck it stands out..
Since i had to take the truck in to get few other things fix and done to the truck, i reported that issue, when i picked up the truck everything except that was done, they said it cant be adjusted or fixed.. but yet you look at other trucks and they are perfect and same height..
Is that true that its not something that can be adjusted or fixed?
thanks..
Old 09-30-2011, 09:01 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
It looks like the door needs to be adjusted, and yes it can definitely be done. If the dealer has a body shop, they would be better at doing that.
Old 09-30-2011, 09:03 PM
Actually the door is fine, late afternoon so pic wasnt that great.. but its only that trim and the dealer told me it couldnt be done..
Old 09-30-2011, 09:08 PM
efx4's Avatar
I'm looking at the bottom picture and the belt moldings (the trim below the windows that run along the doors) seem to line up fine while the top of the doors do not. Actually that may possibly be a problem because to line the door tops up may throw off the belt molding alignment. I would still get a Ford dealer body shop to look at it, and if that's going to be an issue, then you may have to contact Ford or try another shop.
Old 09-30-2011, 09:13 PM
efx4's Avatar
The moldings are fastened in a fixed position and can't be moved, but the top picture shows the very tops of the doors don't look like they line up. The top of one door is higher than the other where they meet, making the moldings not line up.
Old 09-30-2011, 09:36 PM
Ill be washing the truck tomorrow morning so ill get better pics from different angles.. all body lines and doors line up right and the same, its only that trim piece, but ill be taking the truck in again to get some more stuff done to it next week, so ill go with a different shop guy to see what he says..
460 Complete Overhall with pics *Finshed Update !! 1-4-2011 Last Page! Big-old-460 1987 - 1996 F150 & Larger F-Series Trucks 314 09-21-2016 11:38 PM
SES Trims accessories for your Ford Truck at CARiD carid Vendor Specials, Discounts, Product Announcements & Group Buys 0 06-16-2016 05:57 AM
The BlueScab Build Thread BlueScab 1999 - 2003 7.3L Power Stroke Diesel 14 05-11-2016 12:41 AM
51 Panel - Still crazy after all these years! COMPLIT1107 Projects 205 01-22-2015 11:14 PM
My 68 f-100 69SCJ 1967 - 1972 F-100 & Larger F-Series Trucks 15 07-30-2012 09:49 PM
Tags
2007, 2011, door, doors, f150, ford, front, fx4, line, molding, panel, plastic, rear, remove, supercrew
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
