bypassing tank selector valve - Ford Truck Enthusiasts Forums
Old 09-30-2011, 06:10 PM
cdat81986 cdat81986 is offline
cdat81986 is starting off with a positive reputation.
88 f250 5.0
ive already eliminated the rear fuel tank and removed the rear fuel lines. what can i use to connect the front tank return and supply lines together while eliminating the selector valve?
id like to keep the factory lines in place instead of running new rubber supply and return lines if i could.
Old 09-30-2011, 08:24 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You can use a single tank reservoir.
Found at most salvage yards on 86-89 Broncos and Bronco II. On some one tank trucks also.
Old 09-30-2011, 11:59 PM
thanks for the info. ill look at my local pick a part to see if i can yank one this weekend.
do the single tank reservoirs have the same problems as the dual ones? i think my current one is stuck in between tanks at the moment.
anyone else use anything else to take the place of the reservoir? just looking for ideas in case i cant find one immediately.
thanks!
Old 10-01-2011, 05:20 AM
sg1099 sg1099 is offline
sg1099 is starting off with a positive reputation.
finding a single tank resevoiris easy.you can get one out of a bronco,bronco ll,or truck w/ a single tank.you'll just have to clean the crap out of it.literally.i removed my front tank and had to do that.i've got alot of good info off this site.thank you FTE.
Old 10-01-2011, 08:43 AM
subford's Avatar
The single tank reservoirs do not have the same problems as the dual ones.
There is no moving parts. Just the reservoir for the high pressure pump.
Without the reservoir you will engine surging and lack of fuel on hills and WOT operations.
The 1985-86 ones will have a filter in them. If you have a filter on the frame you do not have to put the filter back in the single tank reservoir. But you may have to buy a filter for a 86 to get the "O" ring if you take the cup off the bottom to clean it out.
Old 10-01-2011, 10:32 AM
thanks so much for that info!! in the pick a part near me they have several broncos so finding a reservoir shouldnt be a problem. unfortunately its raining here today, so im going to head out first thing tomorrow to see if i can snag one.
should i have to get on 85-86 reservoir with a filter, can i get this filter and oring at advance?
when i clean and reinstall it is there any benefit just to install the new filter or should i just leave it out? i have a new filter on the frame, i just thought an extra filter wouldnt hurt lol
Old 10-01-2011, 03:16 PM
subford's Avatar
Some trucks in 86 had both the filter on the frame and one in the reservoir. It is up to you if you use both filter if you find one that is made for the filter but the frame filter is on there for the injectors.
Yes Advance auto parts should sell the filter.
A single tank reservoir:
Old 10-02-2011, 04:31 PM
subford,
i went to the junkyard today in search of the reservoir and i got one off of an 88 bronco 2. it looks just like the one in the previous post, and is def a single tank one but the bowl is MUCH bigger. it seems to be a newer part, it doesnt look that old. i almost got one off of a 86 bronco 2 with the shallow bowl (like the one in the pic above) but when i pulled the lines off it they were full of rust so i passed on that one and ended up pulling the one off the 88.
im going to pull the bowl tomorrow and clean it out and replace the filter (if there is one that is)
thanks again for all the help! youve gave me good advice in the past and this time was no exception!!
Last edited by cdat81986; 10-02-2011 at 04:43 PM. Reason: forgot to add something to post
fuel line routing rterril02 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 11-20-2016 01:12 PM
1989 F250 dual fuel tank issue donskrin 1987 - 1996 F150 & Larger F-Series Trucks 11 11-30-2015 08:27 PM
Which fuel line is the supply? shortm 1994.5 - 1997 7.3L Power Stroke Diesel 5 03-10-2012 09:32 PM
Return line or lines routing tootall5764 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 02-18-2011 09:13 PM
Fuel supply and return lines, tank to engine BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-11-2011 01:45 AM
Tags
86, 88, 89, bypass, bypassing, dual, f150, f250, f350, ford, fuel, selector, switch, tank, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
