90 F150 heater blows cold - Ford Truck Enthusiasts Forums
Old 09-30-2011, 05:39 PM
68 351 bronc 68 351 bronc is offline
68 351 bronc is starting off with a positive reputation.
I need help. I have replaced the heater core and radiator thermostat. The engine operates at the correct temp but the heater blows just barley warm air. What do I check next?
Old 09-30-2011, 05:43 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Make sure it is FULL of coolant, if so check the heater hoses to see if they are getting hot, at least as warm as the upper radiator hose.
If all is good there you may have a blend door disconnected/broken under the dash..
Old 09-30-2011, 05:57 PM
Both heater hoses get hot. Is there a common problem to look for with the blend door/ controls?
86 f150 heater problems Dominiqui Archuleta 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-24-2015 05:09 PM
Rear Heater Not Working ianobetz 1968-2013 Full Size Vans 13 02-24-2015 08:17 PM
1976 F100 heater problem FrankTheF100 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-27-2013 02:51 PM
Heater problems Vinford 1999 - 2003 7.3L Power Stroke Diesel 9 11-19-2010 09:47 AM
heater not blowing any heat???99 expedition turnman33 Cooling, Heating, Ventilation & A/C 3 10-11-2006 03:36 PM
Tags
1996, 1999, 90, air, blow, blowing, blows, cold, f150, ford, heater, highway, hot, truck, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
