Battery Power Drain - Ford Truck Enthusiasts Forums
Battery Power Drain
Old 09-30-2011, 12:21 PM
cmiller1229 cmiller1229 is offline
cmiller1229 is starting off with a positive reputation.
Battery Power Drain
1996 F250 PSD 7.3L Automatic transmission has a power drain issue. Went to go start the truck. All it does is click. In order to now start it, It gets jumped by my Dodge Ram 1500 5.2L Any thaughts here?
Old 09-30-2011, 12:54 PM
FloridaCrackerJack FloridaCrackerJack is offline
FloridaCrackerJack is starting off with a positive reputation.
Some times it couldbe the battery. Particals can settle in the bottom of a cell and short the plates. This will cause a voltage drain in the system. If you know the battery is ok you can use a volt meter and remove fuses to pin point the short in your ele.system. A multimeter is very handy I use mine all the time in the shop and around the house.
I hope this helps. If you need more TS details let me know. I have been a heavy equipment mechanic for 30 years and I only own FORDS
Old 09-30-2011, 04:27 PM
I should have mentioned that the batteries are both new.
Old 09-30-2011, 05:27 PM
ichabod40's Avatar
ichabod40 ichabod40 is offline
ichabod40 has a good reputation on FTE.ichabod40 has a good reputation on FTE.
Is your glow plug relay stuck closed? I have heard this is a rather common problem with the PSD.
Old 09-30-2011, 05:32 PM
How do I check that? The GPR was replaced last year.
Old 09-30-2011, 05:58 PM
ichabod40's Avatar
Old 09-30-2011, 07:17 PM
BrianDguy BrianDguy is offline
BrianDguy is starting off with a positive reputation.
I used these to find my battery drain
How to Find and Stop Car Battery Drains – DIY Car Battery Drain - Popular Mechanics
Diagnosing A Car Battery That Runs Down[/URL
The only thing I would do differently is to start by disconnecting the entire PDC before pulling fuses. My drain was a bad alternator, so alot of time could have been saved if I had eliminated all circuts at once.
Old 09-30-2011, 07:42 PM
What is PDC?
Old 10-01-2011, 02:33 AM
nice link brian. that is much better than trying to type it all. I cant type for crap GJ.
'85 L6 300 4x4 Manual Supercab - Draining the Two Gas Tanks? FordBequeather 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 10-15-2015 05:42 PM
1990 Bronco II issues jchandler11 Bronco II 1 08-15-2015 05:55 PM
Battery Drain Issue... Any Help? BigBlue333 1987 - 1996 F150 & Larger F-Series Trucks 6 07-26-2014 12:06 AM
Ac problem Ford12006 2004 - 2008 F150 4 05-27-2014 11:18 AM
Electrical problems....whats draining my batteries? MuddyWaters Excursion - King of SUVs 4 08-02-2010 12:34 PM
Tags
1983, 1996, 250, 73, 97, batteries, battery, drain, electric, explorer, f150, f250, ford, issues, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
