Starters keep going bad?? - Ford Truck Enthusiasts Forums
Old 09-30-2011, 07:41 AM
pilotscoach pilotscoach is offline
pilotscoach is starting off with a positive reputation.
97 F-150 4.6 Starters seem to last about 2 to 3 months then when cold will not engage until i tap on the starter with a hammer. Replace starter and works fine for a couple of months. Been through 5 starters in about 8 months. PLEASE any help with this issue?????
Old 09-30-2011, 09:08 PM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
How far down does your battery drop in start up? Are the starters sucking the amps out of a weak battery causeing it to get hot each start and eventually causing a dead bar on the commutator ( hitting with hammer is a trick to jolt the commutator to move to a live bar completing circuit to spin
Old 09-30-2011, 09:19 PM
21411 21411 is offline
21411 is starting off with a positive reputation.
check the solinod on the fire wall too.
maybe quit buying starters from where ever you are.
my 2000 did the same thing 30 solinod fixed it. sorry i don't know how to spell solinod.
Old 09-30-2011, 09:22 PM
Did replace the selonoid/relay on the firewall
Old 09-30-2011, 09:28 PM
Old 09-30-2011, 09:29 PM
Battery doesnt drop at all
Old 09-30-2011, 09:39 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
I think I would be going with a different supplier..
Old 09-30-2011, 09:44 PM
Starter is from ford and under wwarrnty but i need to fix whatever is causing this issue. put new starter on today and when tried to crank it started to turn over but instantly droped out. Any ideas?
Old 09-30-2011, 09:46 PM
well with a fluke meter on the battery you should see a drop say like example 12.5 volts to 11 or 10.5 inload (cranking) also you can see a possible neg. voltage drop by touching neg.lead to motor instead of battery and pos.lead to battery pos. and read possible neg . voltage drop (loss), then get under there and touch positive lead to battery pos terminal a starter and neg lead on starter housing and read voltage drop in start up (cranking) This is a way to see if starter is getting full battery pos and neg , then to go further you can ohm out the battery pos cable cable from starter to battery pos terminal should be 0.0 to .2 hope this helps it will also give you some insite yo how the system works
Old 09-30-2011, 09:51 PM
Thanks, I'm starting to feel that the problem is a battery cable because every time the problem arrises for a few days i get a pop sound from the radio just after start up. I'm going to give your idea a shot
STARTER PROBLEMS!!! Dr. Johnson 1994.5 - 1997 7.3L Power Stroke Diesel 4 10-07-2013 03:10 PM
Starter grinding birchwoodford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 03-22-2012 12:16 PM
Starter Life? pwauburn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 12-09-2011 10:07 AM
Starter slowing down? fridgeddiesel 1994.5 - 1997 7.3L Power Stroke Diesel 34 04-07-2011 06:12 AM
Starter won't disengage littledonko 1987 - 1996 F150 & Larger F-Series Trucks 9 02-11-2010 11:11 AM
Tags
2003, 2004, 60, bad, badford, diesel, f150, f250, starter, starters
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
