Big Propane Problem Please Help
Hello, my son has a 1999 Ford F-150 with a GFI Dual Fuel conversion LPG/Gasoline. The truck has about 30K original miles. Here is the problem. We live in California and under the rule of CARB. There is a warning light on the dash which won't allow the vehicle to pass the SMOG Test. I took it to the Ford dealer and they told me the trouble codes indicate I have to replace the Propane Compuvalve. But this is for starters. There may be one or more components that may also require replacement starting price ~$4,000. I understand these Compuvalves are notorious for failure as well as being near impossible to find also this would be tough money for my son.
Here is what I would like to do. I would like to remove the conversion and make it a straight gasoline truck. I understand, I think, the PCM is the same for gasoline only it has a program downloaded "Flashed" for the propane module. It seems to me a gasoline wiring harness could be installed and the PCM re-flashed for gasoline taking the propane off-line. I am not sure what else might have to be done to accomplish this or if it will work. Any and all advise would be appreciated. Looking forward to your help. Thank you. Rich
It won't pass on gasoline only? Its Bi-fuel correct? Or do they have to check on both fuels? I am not familar with that system so I am not much help trobleshooting but you might contact a local LP dealer for a referall to a good Non-dealer mechanic.
Then if all else fails sell it out of state.
Good luck
Good luck
I was told by the local smog check that they do not check the vehicle running on propane. They are directed by the computer. I've called every ford dealer in a 300 mile radius and contacted several Propane Conversion companies. No body yet has been able to offer advise. The CARB Referee stated that after, repairs are attempted and a large fee is paid they will give you 2 more years to drive the vehicle. At that point it must be repaired to pass smog or scrapped. Hard luck.
what single part on a propane system could be worth 4000 dollars ?? my bronco was converted to propane for less then 1200 for a new system ..is this just a case of "they can't be bothered to learn to fix it??" or is the EPA /CARB that difficult to work with ?? we hear storys ..but can't believe it is that insane ..you would have to scrap a 10 year old truck because of a smog test?? at 30,000 mils ..strange place you live in....
The bulb has to light up when you first turn the ignition key, or it fails right there. Anyway, part of the test sequence is a code scan. If there are any codes that would throw a Check Engine light, no pass.
Ford parts are presumably much more expensive than old-school LP setups.
With that much money at stake I'd find a good gasoline truck with cosmetic damage and use the cherry 99 for an organ donor then part the rest out if I had to have an F150.
If I didn't have to have an F150 I'd sell it "parts only". Used car dealers often buy "parts only" vehicles because one can fix two or three wrecks. They send the stripped cab to the crusher when done, and those year trucks are very popular.
If you do the "pay large fee then scrap" method, I'd strip that truck bare and scrap the cab and frame in accordance with regs. (Find a printed copy, accept no verbal answer since it's a LEGAL question!)
bsparks72
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-06-2020 09:34 AM
PaulsEdge
Alternative Fuels, Hybrids & Mileage
01-09-2017 07:09 AM
GreenMM
Ford Truck Parts for Sale
13
01-07-2017 08:49 AM
f100drew
16
03-18-2012 09:23 AM
Looking Up
07-20-2009 11:19 PM
