EGT probe
Old 09-30-2011, 01:04 AM
f1501987's Avatar
f1501987
f1501987 is offline
EGT probe
Whats the best place for the EGT probe? In the manifold, or the pipe after the turbo? my truck is a 1997 f250. any ideas? Im thinking after the turbo in the pipe.
Old 09-30-2011, 02:18 AM
Chris56ford's Avatar
Chris56ford
Chris56ford is offline
lost
Pre-turbo is the most accurate place to put the probe, as close to the cylinders as possible.
I have a Autometer gauge and it came with a weld in bung. I placed it in the up-pipe within an 1 inch of the connection of the manifold and up-pipe on the drivers side. Wasn't easy welding it in the there but I didn't want to drill and tap my manifold in case of cracks forming later.
Old 09-30-2011, 07:44 AM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
x 2 on pre turbo
Old 09-30-2011, 09:31 AM
JamesHajek's Avatar
JamesHajek
JamesHajek is offline
Drill and tap the drivers side exhaust manifold. There is a little spot right at the rear of it before it turns up into the uppipe that is perfect to do this.
3-Gauge Install Pictures
That should give you an idea...
It is super easy.
Old 10-01-2011, 06:25 AM
f1501987's Avatar
f1501987
f1501987 is offline
K Thanks For all answers, I put it right after the turbo, on the exhaust pipe. wasn't hard reads good. Ain't much difference between there and pre-turbo and manifold. Used a head laser to read the heat.
Old 10-01-2011, 07:18 AM
Chris56ford
lost
There won't be much difference in temp at idle or when you have low boost, but the temps can vary upwards of 400 degrees when loaded, high boost, hard accel. Here is a thread where someone tested it with 2 probes at the same time.
https://www.ford-trucks.com/forums/4...ost-turbo.html
trekbasso
02-28-2011 02:02 PM
grizzly11
01-03-2011 12:28 PM
rn360908
05-20-2010 11:12 PM
CheaperJeeper
11-11-2006 08:14 PM
f350xlt460
07-30-2003 06:05 PM
Quick Reply: EGT probe
