IAC valve ???????????? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-29-2011, 10:18 PM
Dutter's Avatar
Dutter Dutter is offline
Dutter is starting off with a positive reputation.
I have it unpluged because it make my truck rev on the higher side, and whn i unplug it, it bring the rpms to about 600. And i was hopen thad save me on gas, but would it really ooor not
Old 09-30-2011, 08:47 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
If the IAC is acting out, maybe try removing & cleaning it with a plastic safe spray & see if that helps, if not, replce it as Ford recommends we do when it acts out.
Unless you set around idling the engine all day, disconnecting the IAC won't save much gas & when you turn on some load, the engine is likely to run rough or stall, so the driveability aggravation of disconnecting it, is likely to be worse than the joy of disconnecting it for any meager fuel savings you might get.
Think about it this way, if Ford could have gotten measureably better mpg on the Ranger by omitting the IAC, it wouldn't have gone to the expence of installing one in the first place!!!!
Keep the vehicle in good tune with the tires aired up to spec, use the specified engine oil & Top Tier fuels to keep the fuel system & engine innards clean, modify All of your driving habits, like stay out of the throttle, get into top gear quickly, stay out of stop & go traffic & you'll be more likely to be pleasantly surprised by fuel savings!!!!!
Old 09-30-2011, 04:14 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Hi dutter, I am amazed at all of the issues you have with your truck. How is it that you have so many problems with it? I hope you aren't just making these up for the sake of online conversations.
Old 09-30-2011, 06:58 PM
Dutter's Avatar
yep iv tried cleaning it, and it wouldnt bug me as much untell i hav to slow down i feel the truck down shifting. And i actually tried kooking it thro a switch to see what difference it makes. And i keept the gas at one spot and turnd the IAV one and it make the truck go alittle faster as if i gave it more gas. And yeah i drive that dam truck like a old man untell i get to a down hill lol. And sadly yes i do have ALOT of problems with my truck like right now im blowing on fuse EVER 2 seconds NO JOKE. So i gota track down weres it shorting out because the fuel pump wont turn on with out it. EVENTHOUGH i just re wired the power ground and sending for the pump and put in a new fuel pump. And i was goin to go riden this weekend but i gota get it fixed to get to school. grreeaaattttt and yeah now i cant really harp on chevys now . And all of this happened in the past 3 days
Old 09-30-2011, 07:58 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
Your truck is roughly 17 years old. That's quite the age these days. With all the electrical components used, even in 1994, the problems are bound to stack on. If your IAC is causing the idle to rise, then clean it, or replace it. If your idle is still high, check to see if the idle has been adjusted by someone else. I know on my 03, idle adjustments using the idle screw are highly frowned upon because any adjustments not set by the factory can hinder performance.
Old 09-30-2011, 09:41 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
I have had mine disconnected for about 200000 miles. Yes I adjusted the set screw and it idles at around 700 rpm with/without ac on. We tried to trouble shoot and after all ,the codes found that there is a shorted wire someplace in the harness. Guy had all kinds of manuals which we kept referring through as the scanner codes kept changing and the manuals kept getting deeper and deeper into the system. All the IAC is supposed to do is up the RPM when the AC is one supposedly. I dont miss it at all.
Old 10-01-2011, 12:11 AM
Dutter's Avatar
lol yep the truck is about the same age as me. So yeah its no surprised its had it problems. And all the chevy guys harp on it, but there in newer trucks and this truck has been thro hell and back. And yeah i think ill eather lower the adjuster with IAC on or raise it with it off. Because here in CA theres that stupid smog *****, even tho im in North CA were its nothing but good ol boy pot growers
Old 10-01-2011, 08:47 AM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Quote:
what year truck? pretty common problem on the 98-2000 models. The TPS wires short out and cause the IAC to malfunction. Easy fix...
Old 10-01-2011, 11:04 AM
its a 94 4.0. Have no problems as stated so not gonna worry about a repair.
unplugging idle motor drunkenrich 1987 - 1996 F150 & Larger F-Series Trucks 5 06-10-2010 08:55 AM
ebpv disconnect gunnar7.3-9 1994.5 - 1997 7.3L Power Stroke Diesel 16 12-25-2009 07:11 PM
Unplugged ICP palaka 6.0L Power Stroke Diesel 9 12-09-2009 12:55 PM
To unplug or not to unplug? oldbird1965 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-08-2008 10:19 AM
unplug the IAC? what happens? dbuck50 1987 - 1996 F150 & Larger F-Series Trucks 2 10-25-2003 11:19 AM
Tags
1986, 1994, 94, broncoii, cleaning, ford, iac, ranger, replacement, show, truck, trucks, tv, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
