E4OD shifts hard from 1st to 2nd
My F150 shifts hard from first to second, the vss in the rear differential was broke off, so i recently replaced it thinking that it would fix the problem. It did not. I have the battery unhooked to reset the computer and see if it does anything. Any input would be much appreciated!
The following users liked this post:
i do think it needs to be adjusted because on the dash it doesnt always line up when it says its in gear, like reverse would be half way in to the R not all the way, do you know of any way to tighten it up? its too dark now, but i gotta replace the rear brake line tomorrow morning, so i can check that too.
I've pulled my electrical connector off and sprayed it with contact cleaner, then reassembled it with dielectric grease, but it didn't help. I'll change mine soon and hope it helps my problems.
Good luck with yours!
I'll look into that. Do you think that the rear antilock and brake light on the dash could cause the computer to think something is wrong making it shift hard? dad and i just replaced the line today so now the rear brakes work. but the two brake warnings are still on. the rear anti lock goes off for about 3 seconds and goes right back on, and i think the check engine light blinks 3 times now, and shuts off
its my first truck, i paid 800 bucks for it so i didnt ask for perfection, i wanted something to work on, which i got, but the guy i bought it from, never mentioned anything about the transmission shifting hard. I'm going to drop the pan, and change the accumulator spring because its a constant hard shift, the harder you are on the throttle the harder the slam. I hope it cures the problem. Any more ideas would be appreciated. If it helps any my truck is a 91.
