2011 F-250 .. dash auxiliary switches.. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-29-2011, 05:02 PM
tuscany tuscany is offline
tuscany is starting off with a positive reputation.
that come OEM from factory. Do any of you know if the same switch can be got as a momentary type switch instead of the on/off switch?
Old 09-29-2011, 05:32 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
I don't think you can get a matching momentary switch, but you can modify the switch to be momentary. See this thread:
http://www.ford-trucks.com/forums/40...info-here.html
Old 10-30-2011, 06:22 PM
Fleetsuper's Avatar
Fleetsuper Fleetsuper is offline
Fleetsuper is starting off with a positive reputation.
Installing switch bank
Has anyone added auxiliary switches to a truck that didn't come with them? Is there a kit one can buy from the dealer?
I just picked up a '11 F250 and it didn't have them and that was one of my "must ave" options and I would love to install them and have it be as original as possible.
Old 10-30-2011, 06:31 PM
bpounds's Avatar
2 bit Californian
Sure you can. Any dealer can sell you the parts, but the easiest is to buy from a source that knows what is needed.
www.partsguyed.com
Old 10-30-2011, 08:12 PM
I have not yet had a chance to try the switch conversion....just bought another '11 F-250 w/6.7
Old 10-30-2011, 09:56 PM
Robhall Robhall is offline
Robhall is starting off with a positive reputation.
Easy install
I got the kit off of a dealer on ebay. cost was 135 or so. Included switches, relay, and wiring harness with nice printed instructions. Took about 30 munutes with a screwdriver and flashlight under the dash to install.
Old 10-30-2011, 10:11 PM
Fleetsuper's Avatar
Quote:
www.partsguyed.com
Hey, you da man! Thanks, that's just what I was looking for, I really appreciate it greatly.
Old 10-31-2011, 01:21 AM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
Upfitter switch installation instructions and part numbers can be found in the PDF document at the following link...
http://www.fleet.ford.com/truckbbas/non-html/Q157R1.pdf
NOTE: P/N: BC3Z-14A303-A (Wire Harness) has been superseded by P/N: BC3Z-14A303-B
Old 10-31-2011, 07:55 AM
Fleetsuper's Avatar
Thumbs up
Thanks for this tech sheet, that helps me immensely. Maybe you or another member can help with my next part of this little project.
One of the items I wanted to add to the switches once installed is to have one of the switched set so I can flash my tail lights while towing. Is there a bulletin for that procedure, or has another member done this?
Thanks again,
Mfs switch Natedoggy77 Ranger & B-Series 1 01-19-2012 02:51 PM
1968 F250 Kill switch fzeed 1967 - 1972 F-100 & Larger F-Series Trucks 13 02-18-2009 05:06 PM
Upfitter switches Froglips 1999 to 2016 Super Duty 17 09-14-2008 09:23 PM
Upfitter Switches davidwruth 1999 to 2016 Super Duty 5 02-18-2007 06:24 AM
NO OIL PREASURE AT SWITCH HELP!!!!!!!!!! JBronco 1978 - 1996 Big Bronco 5 10-09-2002 07:17 PM
Tags
2011, 250, aux, auxilary, auxiliary, control, duty, f250, f550, ford, series, super, switch, switches, tuscany
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
