305/65/18 bfg at - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
305/65/18 bfg at
Old 09-29-2011, 11:55 AM
highridercf highridercf is offline
highridercf is starting off with a positive reputation.
305/65/18 bfg at
Does anyone know if i can fit a 305/65/18 bfg all terrain on my stock 18/ 8.5 wheels or is it going to be to wide? The stock size was 255/70/18, so is it going to look odd with the smaller side wall? havnt been able to find a pic of an 07+ expy with bfg ats.
Old 09-29-2011, 01:59 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Tire Rack specs for that size says 9" rim, my guess is you won't notice the difference with an 8.5.
The tire store you buy from should let you look at one mounted up before you complete the installation.
Old 09-29-2011, 07:39 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
the 305/65/18 you are asking about has more sidewall than your OEM tires. it is a 33.5" tall tire. Your factory tires are a 32" tire
I'm running a 275/60/20 (33") on my 4x2 Expy right now with ZERO rubbing issues. But that is because I only went up in height, but kept same width.
Your new tires will be 2" wider than the OEM tires. Your best bet is to turn the wheel all the way to the stop 1 way. Get your head in there and measure all the gaps you have. Shorten that gap by 1" to account for new tire.
Be sure to also look for clearance while tire is compressed and turned. Your new tires are only 1" wider than the tires I'm rocking right now. So you only have to clear another 1/2" from components than I currently do. I'm fairly certain you'll be fine. Especially if you are a 4x4 (sits 1" taller).
aren't the 17" and 18" rims only a 7.5" width? I know they are on the F-150. Makes sense if the Expy were as well since they are basically the exact same vehicle. 20's are 8.5" wide due to narrower sidewalls
not saying it's right, but I know alot of F-150 guys rocking 305, 315, and 325 width rubber on their OEM 7.5" wide rims
305/65/18 on stock 8" rims Grosjo 1999 to 2016 Super Duty 8 06-11-2014 09:21 AM
305/60/18, Factory 18"s, no lift or level MCDavis 2004 - 2008 F150 7 04-05-2012 07:08 PM
Will 305/65/18s fit stock F350 Nathan 1999 to 2016 Super Duty 3 11-08-2010 07:11 AM
Anyone Running BFG All-Terrain T/A KO 305-65-18 On Stock 18" Rims??? SeanMatteson 2004 - 2008 F150 15 04-08-2008 10:27 AM
305/65r18 TheDuke 1999 to 2016 Super Duty 14 09-08-2007 09:03 AM
Tags
18, 2009, 2010, 2011, 305, 30565, 3056518, 65, bfg, dutyu, f150, ford, rockstar, sale, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
