1949 dana axle/bearing same as 1961 9"? - Ford Truck Enthusiasts Forums
Old 09-29-2011, 11:32 AM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
i know the hub, bolt pattern are same, are the dana axle and the 9" axles interchangeable?? length, bearing size/location, spline count? i have a noisy bearing in my 61 9" and two good dana axles sitting around. thanks, dick r.
Old 09-29-2011, 12:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I'd be amazed if they were compatible, and 9"-ers have different bearings, some tapered, some not. Bearings themselves are cheap, installation on a 9" with the retaining sleeve is a pain.
Old 09-29-2011, 04:06 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by r_reed View Post
i know the hub, bolt pattern are same. Are the dana axle and the 9" axles interchangeable??
Absolutely not, 2 different animals...not one rear axle part interchanges.
1961 F100's use the large 9" axle bearing (there are 3 others, medium, an axle bearing/seal combo introduced in 1974 and the type used with the 9 3/8" ring gear).
The large bearing will be found in all 1961/65 T-Bird's & full sized Ford/Merc station wagons. All 1961/67 F100's, 1966/73 Bronco's.
Some 1974/86's have the large bearing, some have the axle bearing/seal combo. Some 1968/73 have a 9 3/8" ring gear, some do not.
Axle bearings have BIN's (Bearing ID Numbers) stamped on them, autoparts stores/bearing shops go by these numbers.
Old 09-29-2011, 07:28 PM
r_reed's Avatar
thanks, that's pretty clear. that's what i like, a definitive answer. guess i'll pull the axle and turn it over to napa. thanks, dick r.
What size wheel/axle bearing for Dana 44 Rear? medino03 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-25-2014 09:51 AM
'66 Dana 44 rear axle removal 37 Ford guy 1961 - 1966 F-100 & Larger F-Series Trucks 12 07-24-2012 05:03 PM
Dana 61 to 60 swap AerostarDad 1973 - 1979 F-100 & Larger F-Series Trucks 18 03-21-2010 10:34 AM
Dana 61 to 60 swap AerostarDad Clutch, Transmission, Differential, Axle & Transfer Case 4 03-07-2010 07:03 PM
1/2 ton Rear Axle Bearing R/R, axle housing Inspection, Ford 9" 1975Ford Clutch, Transmission, Differential, Axle & Transfer Case 15 11-21-2005 11:19 AM
Tags
1949, end, ford, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
