2002 F150 4x4 5.4L Oil Type Questions - Ford Truck Enthusiasts Forums
Old 09-29-2011, 10:58 AM
feo_nuts feo_nuts is offline
feo_nuts is starting off with a positive reputation.
Hello everyone.I finally got rid of my ole blue bitch (1988 F150) and bought a "new to me" 2002 F150 4x4 with 125,000from my uncle. I love it! It had the check engine light on for 80,000 miles. He's QUITE the exagerater. WIth all that being said, it was throwing a lean code and the culprit was the FPR. Ok, my truck runs great, has for 3mo, no codes no nothing. The question I have is the reccomended oil is 5w-20. When I changed the oil, this is what I used. I always throw a can of lucas in it for good measures. It seems in the cooler temps, around 50-60 degrees, which ain't even really "Cool" that just on a start up, it seems to tick for a few seconds. Not knock, not clank, just tick. Almost as slight as an air tick, but when the engine warms, it goes away. This tick, only usually last for no longer than a couple of minutes. I was wondering, if it would hurt if I would change to 10w-30 oil if this would help/hurt? I doubt it, but I was just wondering. I would like your insight on all. I don't want debate, just answers and experience. Thank in advance!
Old 09-29-2011, 12:43 PM
jgeese jgeese is offline
jgeese is starting off with a positive reputation.
If what you are hearing is indeed a oil related/cold start ticking, changing to a heavier oil would only amplify that condition. Also note, that oil pressure is used for tensioning the timing chains in the modular engines. Although some may disagree, heavier oils may accelerate the wear of tensioners. Personally, I use 0w-30 in our truck with success during boating season, a 5w-30 may work as well in the summer. Having said that, typically winters here a somewhat mild...
Old 09-29-2011, 02:43 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Save your money by not putting any more oil additives in and stick with 5w20. Your tick could very well be piston slap and no kind of oil or additive will fix that.
Old 09-29-2011, 02:48 PM
Piston slap?
Old 09-29-2011, 04:01 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Go back to the reccomended 5w20 and use a Motorcaft filter all year around.
....Use no additives and especially not for good measure.
....The cold 5 weight part allows the oil to get to the valve train faster as well as the cam chain tensioners. This keeps chain related noise down at starting as well as reduces long term wear.
....Using heavey oils and viscosity additives causes excess wear on the chain tensioners as well as slows cold oil circulation.
....You have to abandon the old type thinking about engines and oils.
....Your already seeing the effects of doing it.
....This engine design is completly different than a push rod engine.
....Do not take the position, the factory reccomendation can be improved upon with other oils and additives.
....These engines are running over 200,000 miles on 5w20 as compaired to engines of 20 years ago for an average, on factory reccomened oil.
....You got my insight from knowledge and experience. There will be no debate from here.
Good luck.
Old 09-29-2011, 04:29 PM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
My knowledge from being into modular mustang racing is this. 5w20 is good, 5w30 is good, no more than that. You can run a 0w of either of those. In fact having talked to a few mustang engineers, the motor is designed for 5w30 but 5w20 is recommended for emissions reasons. I personally run Amsoil 5w30 in my modular. Never use additives. I finally got my buddy to stop using Lucas and he was like "Wow, it revs faster and doesn't tick".
2000 f150 v6 ticking sound? drumrooster 1997 - 2003 F150 1 03-02-2016 12:07 PM
Engine Ticking Noise on 2004 F150 5.4L 3 Valve thompsdw Modular V8 (4.6L, 5.4L) 22 10-21-2014 02:26 AM
Please Help!! 2008 f150 5.4 ticking Problem. TrukProblemz 2004 - 2008 F150 5 02-10-2014 03:51 PM
5.4L engine is ticking. Stangfire 1997 - 2003 F150 8 01-20-2013 07:24 AM
Ground up Timing Chain Guide....and timing cover Woodlums 1997 - 2003 F150 5 01-12-2012 08:30 AM
Tags
150, 1997, 2000, 2002, 2010, 54, 54l, additive, f150, ford, oil, specs, type, viscosity, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
