turns over strong but won't fire - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-29-2011, 06:45 AM
brokeisnojoke's Avatar
brokeisnojoke brokeisnojoke is offline
brokeisnojoke is starting off with a positive reputation.
Im back and its been a long while. My truck is cranking strong as ever but wont start. Updated: ffor anyone that remembers me. I have changed cps, ipr, tested hpop (4000 psi), new water pump and recently bought another computer. My truck just wont fire, not even on ether. I kno not to use it but im getting desperate to get the turd on the road by winter. I need help bad!
Old 09-29-2011, 07:59 AM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
do you have a chip? if so might be worth removing and see if it cranks then. do you hear any relays under the hood clicking? thats the problem i have right now. are you getting any DTC's?
-cutts-
Old 09-29-2011, 08:08 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Isn't that a lot of psi from the hpop just cranking???
Old 09-29-2011, 08:46 AM
The hpop should have 3 to 5. New comp is bone stock. Gpr clicks over but no fire. Everything seems normal except it wont start
Old 09-29-2011, 08:49 AM
mq1shooter's Avatar
mq1shooter mq1shooter is offline
mq1shooter is starting off with a positive reputation.
Ok, that's a start.....
#1) Charge the batteries....cause they run down quickly and no need to tax them...
#2) HPOP, a square or Hex looking plug is on the top...verify you have oil within 1/2" +/- of the top... extended cranking may lower the HPOP res. and will show up on your crankcase dipstick as a "over-serviced" at least it did with my thread / No start.
#3) Disconnect the ICP electrical plug, and try to start it with it disconnected, may see a "CEL" light illuminate on your dash...
#4) Check your Fuel pressure from the Schrader Valve ( tire stem) valve Fuel Bowl area) with a cheap tire gauge during a cranking session...you'll get a little wet with diesel, but focus on the gauge - as it will pulse- and "ballpark" a PSI during the cranking session.
#5) thats a start...other will chime in
#6) Smoke from the tail pipe when trying to start?
#7) I assume you have a WTS lamp, and NO CEL light illuminated?
#8) How many miles and how old the oil?
Old 09-29-2011, 08:58 AM
Hpop level is good. Wts lamp does come on. Oil is probably around 3 months old but has maybe 100 miles on the oil. Motor has around 110k on it.
Old 09-29-2011, 10:20 AM
i know you said you changed the cps but does your tach move when cranking?
-cutts-
Old 09-29-2011, 11:17 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Question
Have you checked the maxifuse #22 (IIRC) underhood?
Old 09-29-2011, 11:33 AM
Yes tac moves. I checked them a few months ago I will check again when I get off work.
Old 09-29-2011, 12:26 PM
78pace's Avatar
78pace 78pace is offline
78pace is starting off with a positive reputation.
Did you try a working IDM. Mine did that about a month ago. Crank all day long no fire, replaced IDM fired right up.
Old 09-29-2011, 02:12 PM
How much was the idm? Iv already got around a grand under the hood from replacing crap
Old 09-29-2011, 04:30 PM
78pace's Avatar
Mine was.a spare. EBay after core is $250 I believe
Old 09-30-2011, 11:21 AM
That's not to bad then. It was pouring yesterday so I didn't get a chance to check that maxi or test fuel pressure
Old 10-02-2011, 06:00 PM
New idm and still will not fire. I am running dry on this! Is there anything else that wouldn't let the injectors fire?
Old 10-02-2011, 08:06 PM
No smoke. Wts light comes on. Relays click over. Checked idm connection. Getting sick of dumping money into this truck
Cranks, won't fire, no engine codes Jxltrucking 6.0L Power Stroke Diesel 9 01-15-2015 01:03 AM
2001 PSD 7.3 won't start demondiesel 1999 - 2003 7.3L Power Stroke Diesel 3 06-30-2014 09:53 PM
my bronco cranks but wont start broncoboy20 1978 - 1996 Big Bronco 18 06-17-2013 01:49 AM
1991 5.8 what makes the injectors work? rustfixer 1987 - 1996 F150 & Larger F-Series Trucks 4 08-16-2010 11:13 PM
76 460 slow cranking after degreasing motor 77camperspecial 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-19-2006 09:40 PM
Tags
1996, 2000, 239, 73, block, crank, diesel, dodge, f350, fire, ford, ram, start, turns, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
