Its cracked, but what is it? - Ford Truck Enthusiasts Forums
Old 09-28-2011, 07:06 PM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is gaining momentum as a positive member of FTE.
Hey everyone!
I had my truck up on my lift to change the oil and when I lowered my spare to check the air, I noticed a module of some kind that is bolted on the cross member directly above and to the left of the spare tire. There are 2 cracks on the plastic case, and the lower crack is even into the aluminum housing that bolts to the truck. I cleaned it good and put some silicone sealant over the cracks to try and prevent any water or dirt from entering. Who knows how long its been like this and if there isnt already dirt, water and corrosion reaking havoc on the insides? So what is this thing and what does it do? Should I replace it?
Thanks for reading!
Old 09-28-2011, 07:23 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
No Clue, did you trace the wires and see where they ran too that might shed some light onto the matter.
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
Fuel Pump driver module. The are notorious for cracking, breaking, leaking and shutting off power to your fuel pump. If yours has been cracked for a while i would think about replacing it sometime before it leaves you stranded. Just take that part number on the sticker that is visable in the one pic and go to the dealership and get a new one.
Old 09-28-2011, 08:03 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
That is the "Fuel Pump Driver Module" as stated, it is an aluminum housing with pastic cover bolted to the frame and when you remove it, you may find the whole rear of the housing where the aluminum was in contact with the frame corroded away. I've seen some so bad you could see the electronic guts potted inside. They will leave you stranded if they fail.
Yours is already broken. You will see when you pull it off that the surface to which it is bolted is not "flat". Tightening the bolts is likely what broke yours.
When you get the new one, Ford also has a kit designed to space the FPDM off the frame rail so a 1/4" or so gap is behind it so no contact between steel frame and aluminum housing. Use the kit or devise your own method.
I read a thread on the subject last year and checked mine and found corosion started. I cleaned it, clear coated it heavily, and got some longer metric bolts that fit the threaded holes, cut the heads off to make long studs, locktited the studs in the frame holes and used a nut to tighten up. Then I placed washers on those nuts and the FPDM and another pair of washers and secured with nylock nuts avoiding overtightening.
When first looked at FPDM
Corrosion just starting
Frame underneath
Cleaned and clearcoated heavily
Back in place ... also had cleaned and throwed some paint on the frame part
Mine is unplugged in last pic, I had to repair a wire I found almost chewed through, no doubt by a darn squirrel. I also threw a couple zip ties on there buit I really don't think there's much chance of the nylock nuts loosening up, just a moment of "redundent overload" I guess.
Old 09-28-2011, 09:35 PM
mercman86's Avatar
Thanks guys for all the info. I will probably just replace it soon. I'll give the dealer a call tomorrow to see how much an OEM one will cost. I know dorman makes one but I am always wary about buying aftermarket electrical parts especially if it is a china special.
Old 10-02-2011, 04:24 PM
mercman86's Avatar
I ended up ordering a doorman unit from rock auto. 66 bucks with shipping. I installed it today and all seems well. The new one came with rubber bushings to isolate it from the frame rail. The case was so corroded that there was almost a hole in it on the back.
Thanks for all the info!
F100 Thomo5150 1973 - 1979 F-100 & Larger F-Series Trucks 44 05-21-2013 09:56 AM
2011 Escape. Does it look totaled? mercman86 Escape & Escape Hybrid 29 01-04-2013 07:01 PM
Super Duty's home got a facelift! lots of pics gilby959798 1999 to 2016 Super Duty 19 06-22-2012 09:15 PM
My 74 f-100 project David LaPell 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-27-2011 08:41 AM
Weekend run CanadianSmokie Excursion - King of SUVs 17 11-26-2009 12:30 PM
Tags
2001, 200ci, 97, broken, cracks, dorman, engine, f150, ford, fpdm, iwe, location, matter, small, spare, taurus, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
