'95 F-150 Heater Core Replacement - Ford Truck Enthusiasts Forums
Old 04-07-2003, 02:08 PM
Travis Peters Travis Peters is offline
Travis Peters is starting off with a positive reputation.
Exclamation '95 F-150 Heater Core Replacement
Last week I experienced coolant steam entering the cab and immediately suspected a heater-core leak. I disconnected the waterlines that enter at the firewall and re-routed one of them back into the engine, thus by-passing the core all together. Now, time to fix the problem... I've never attempted a Heater Core in any vehicle...can someone give me a rough idea of the process on my vehicle. I've seen some F-150 seem quite easy, and some require complete dash removal. What's involved?
Help is appreciated!
Old 04-10-2003, 09:45 PM
billa billa is offline
billa is starting off with a positive reputation.
did you ever get help on this? how did it turn out for you?
I may be facing same on 97f150.
Old 04-10-2003, 10:02 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
I don't have the data file on the '95 F 150 but I know the '95 Explorer needed to have the dash removed.
The '97 will need to have the dash removed. Some of the manuals I've seen say the AC system needs to be vacuumed prior to removing the dash and then recharged after the heater core is replaced for these models.
It's bad that you may have to remove the refrigerent, but you also have to remove the airbags before you remove the dash
The manual (DVD) also says that 2 people are required to reinstall the dash.
Heater Core Shut Off Valve TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 18 07-18-2015 01:20 AM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 03:05 PM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 08:55 AM
1996 Changing Heater Core rlay302 1987 - 1996 F150 & Larger F-Series Trucks 5 02-12-2011 10:39 AM
97 F150 Heater Core fabian1031 1997 - 2003 F150 6 04-15-2009 03:23 PM
Tags
1995, 1998, 95, core, f150, heater, intstructions, leaks, located, location, plugged, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
