Bed Rivets
Old 09-28-2011, 06:43 PM
CrazyDog66's Avatar
CrazyDog66
CrazyDog66 is offline
Bed Rivets
I have the bed of my 49 F1 totally torn down, tomorrow the rear crossmember for the bed frame should be here along with all the rivets.
How do I go about setting the rivets?
My thoughts are I'll install them and put a small spot weld on the backside.
What is the proper way?
Old 09-28-2011, 08:15 PM
49willard's Avatar
49willard
49willard is offline
The easiest and best way to set rivets properly I have found to be using an air inpact gun with a rivet setting bit in it. I purchased my bit from Jim Dix at Big Flats Rivet in (I think) Horseheads NY. I just got a sale flyer from HF that had an impact gun with several different sized bits. After inserting the rivet in the sheet metal, cut the protruding rivet shank length to approximately 1 1/2 times the rivet shank diameter (to properly form the head). Make a bucking bar out to a chunk of metal (need some weight). I dimple a crater in the bucking bar to be held firmly against the rivet head. Note that it is easier to do with a helper on the bucking bar. Then heat the extended shank of the rivet to cherry, push the tool firmly against the shank end of the rivet and a quick burst from the air impact will form a perfect head.
Last winter I did a major re-rivet job on a frame replacing 110 rivets!
pin8246
05-05-2014 01:30 PM
77_150
01-07-2011 02:31 PM
ghunt
General Automotive Discussion
10-07-2008 08:47 AM
dieingford
Paint & Bodywork
02-13-2004 09:35 PM
KJKozak2
08-12-2002 03:28 PM
Quick Reply: Bed Rivets
