Bed Rivets - Ford Truck Enthusiasts Forums
Bed Rivets
Old 09-28-2011, 07:43 PM
CrazyDog66's Avatar
CrazyDog66 CrazyDog66 is offline
CrazyDog66 is starting off with a positive reputation.
Bed Rivets
I have the bed of my 49 F1 totally torn down, tomorrow the rear crossmember for the bed frame should be here along with all the rivets.
How do I go about setting the rivets?
My thoughts are I'll install them and put a small spot weld on the backside.
What is the proper way?
Old 09-28-2011, 09:15 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
The easiest and best way to set rivets properly I have found to be using an air inpact gun with a rivet setting bit in it. I purchased my bit from Jim Dix at Big Flats Rivet in (I think) Horseheads NY. I just got a sale flyer from HF that had an impact gun with several different sized bits. After inserting the rivet in the sheet metal, cut the protruding rivet shank length to approximately 1 1/2 times the rivet shank diameter (to properly form the head). Make a bucking bar out to a chunk of metal (need some weight). I dimple a crater in the bucking bar to be held firmly against the rivet head. Note that it is easier to do with a helper on the bucking bar. Then heat the extended shank of the rivet to cherry, push the tool firmly against the shank end of the rivet and a quick burst from the air impact will form a perfect head.
Last winter I did a major re-rivet job on a frame replacing 110 rivets!
'53 F-100 FRONT BED PANEL RIVETS jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-25-2015 11:46 AM
Front Bed Panel Replacement? Smitty49 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-28-2014 06:13 PM
Hood Latch Rivets cts1954 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-17-2014 10:45 AM
1954 Bed Panel Rivets 1954_NJ_F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-04-2012 10:40 AM
VIN tag rivets dentsideranger 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-01-2008 02:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
